ScottNM Posted May 16, 2011 Share Posted May 16, 2011 How much hp/tq do you think this unit will have. I have a very good deal to purchase it. thx So This motor was recently removed from a 2nd generation camaro. This motor runs excellent and has just over 1900 miles on it since it was totally built. It is barely broke in. It is a 289 casting 454 that was bored .030 with a deck plate, hypereutectic pistons, polished crank, ARP rod bolts, new head bolt kit, and a new stock oil pan. The cam is a Competition Cams extreme series hyd cam. comp push rods, valve springs, lifters, and Moroso chrome valve covers. It has an edelbrock air gap dual plane intake manifold and a holley fuel pump. All of the brackets, pulleys, and PS pump are included in the auction. This motor just needs your carb and it is ready to bolt in. It has a grumpy idle and sounds very nice. The heads are the open chambered 781 castings with all new valves, springs, and 1.7 roller rockers. This is a very nice street motor, pro street motor. I can shink wrap the moto and put this on a pallet and have it ready to ship. The buyer is responsible for all shipping costs. Parts List for Engine: TRW -8KH426CP30 COMPETIOTION CAM -CCP-CL11-242-3 CAM SPECS GRIND NO. CBXE268H10 1600-5800 RPM COMPETIOTION CAMS TIMING SET-CCA-2110 COMPETITION CAMS PUSH ROD SET-CCA-7854-16 ARP BBC 3/8 WAVE-LOC HI ARP-135-6402 MELING HIGH VOLUME OIL PUMP SES-3-90-08-003 OIL PAN SUMMIT SUM-G3510X FEL PRO GASKET SET FEL-KS2618 ARP HEAD BOLT KIT ARP-135-3601 ARP INTAKE BOLT KIT BBC 12 PT ARP-135-2101 EDELBROCK AIR GAP INTAKE MANIFOLD Quote Link to comment Share on other sites More sharing options...
ScottNM Posted May 16, 2011 Author Share Posted May 16, 2011 The TRW #pistons listed is for no more that 9 to 1 compression. Can you get 420-450hp out that kind of compression? Quote Link to comment Share on other sites More sharing options...
Mike 57 Posted May 16, 2011 Share Posted May 16, 2011 To be honest I think you will be lucky to top 400. Sounds like cast crank and stock rods. Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted May 16, 2011 Share Posted May 16, 2011 Quote Link to comment Share on other sites More sharing options...
Andy's Auto Posted May 16, 2011 Share Posted May 16, 2011 It looks like a very reliable build but leaves quite a bit on the table. But 335-360 at the rear wheels sounds about right. It wil make a Monte with the right convertor and gears into a solid low 13-high 12second car. Definately a torque type build. Quote Link to comment Share on other sites More sharing options...
ScottNM Posted May 17, 2011 Author Share Posted May 17, 2011 Forgive me for my inexperience but what makes one 454 engine have 425hp and 500#tq and another 454 engine has 450hp and 480# tq? Quote Link to comment Share on other sites More sharing options...
72 LS5 Posted May 17, 2011 Share Posted May 17, 2011 I just saw the ebay ad - the pix are hard to see, but with only 1900 miles, I would think the paint would look fresher than it does. Looks more like a 19000++ mile motor with the faded paint and grime. Did he send you better side-view pix? I agree with the others about the hp. Good torque to pull around a Monte. Quote Link to comment Share on other sites More sharing options...
72 LS5 Posted May 17, 2011 Share Posted May 17, 2011 Forgive me for my inexperience but what makes one 454 engine have 425hp and 500#tq and another 454 engine has 450hp and 480# tq? This usually has to do with cam selection. Generally, as the cam size gets bigger, the hp increases - but at a higher rpm. Low end torque usually drops off because of the mathematical function of hp and tq. The one constant is that hp will always equal tq at 5250 rpms on any motor - that's where the lines of the graph always intersect. Once you start getting into bigger cams, you will have to start looking into higher stall converters and steeper gears to compensate for the loss of low end torque. Quote Link to comment Share on other sites More sharing options...
ScottNM Posted May 17, 2011 Author Share Posted May 17, 2011 One more question for now. I am trying to find a 454/450hp crate engine. I want to do it right the first time. I am going to post two units with specs. Any feedback on which one looks better would be appreciated. 1.The balanced rotating assembly includes: 4.00" stroke nodular iron crank 6.135" forged rods with ARP rod bolts 9 to 1 compression pistons More special features of this engine include: Seasoned 2-bolt main block Deck head gasket surface on block to ensure a good seal New Hydraulic flat tappet cam with .527"Int/.553"Exh valve lift New Valves 2.070"Int/1.720"Exh New 1.440" high performance springs with dampeners setup to match cam New Rocker studs New Hardened guide plates New 1.7 roller tip rocker arms - these allow us to use stock height valve covers so your stock brackets fit without any modifications New Hardened push rods New Perfect Circle rings New Double row timing set New High volume oil pump with steel drive shaft and steel guide with oil pickup tube welded to pump New Revolutionary 1-pc design molded rubber oil pan gasket with load limiters to prevent over-tightening and higher temperature resistance than standard cork-rubber gaskets New Brass expansion plugs New Edelbrock dual plane intake manifold All parts are painted separately before assembly for that show quality look This engine comes completely assembled with oil pan, timing cover, harmonic balancer, valve covers, and Edelbrock dual plane intake manifold. 2. MARK IV BLOCK 2 PEICE REAR SEAL SELECT CORE Hot Tank VATTED BORED WITH NEW STYLE COMPUTER EQUIPMENT 454 STEEL CRANK NEW EAGLE STD STD NEW INTERNAL PARTS LIST NEW 454 CRANK EAGLE STEEL FOR INCREASED TORQUE AND POWER NEW FORGED RINGS MOLY AND PISTON SETS NO JUNK .. NEW CAM BREARINGS AND ROD BEARINGS STD SIZE FORGED RODS GM NEW CUSTOM MADE CAMS HYDRUALIC NO MAINTENANCE NEW ROLLER CHAIN NEW COMP CAMS PUSHRODS NEW OIL PUMP AND SCREEN TRW NEW TIMING COVER NEW FELPRO GASKET SET NEW FULL ROLLER ROCKERS NEW STAINLESS VALVES NEW EDELBROCK RPM INTAKE NEW HEADBOLTS AND HARDWARE NEW 7 QT OIL PAN NEW TIMING COVER NEW BALANCER PORTED GM OVERSIZE VALVE HEADS HI FLO VALVES 2.19/1.90 STAINLESS AND SEALS AND SPRINGS MATCHED TO CAM GREATLY INCREASES POWER AND TORQUE OVER STOCK GM HEADS NEW ROCKERS 1.7 RATIO AND CAM SPECS OF 590 LIFT INTAKE 990 EXHUAST 110 CENTERLINE RPM RANGE 1600 RPM TO 5500 EACTLY NEEDED ON THE STREET NEW DUAL PLANE POLISHED RPM INTAKE 1800 THRU 5600 NOT SHOWN ENGINE COMES FULLY ASSEMBLED VALVES ADJUSTED AND OIL SYSTEM CHECKED. Quote Link to comment Share on other sites More sharing options...
Ian Posted May 17, 2011 Share Posted May 17, 2011 This is the one I want to order for mine.. GM ZZ454 with Alum heads Quote Link to comment Share on other sites More sharing options...
ScottNM Posted May 17, 2011 Author Share Posted May 17, 2011 After alot of research, I am going with "vortecpro". Mark has a stellar reputation nationwide. Here is my unit. 467 517 HP 564 TQ 9.1 compression Excellent muscle car engine replacement, excellent vacuum, very street friendly Dyno tested $4995.00 Quote Link to comment Share on other sites More sharing options...
zmanabba Posted May 17, 2011 Share Posted May 17, 2011 Good choice on going with Mark. When he first started there were a lot of skeptics. But he has excellent customer service and his engines do what he claims. So he now has an excellent reputation. There will only be two problems with your choice: the long waiting list and having to change rear tires frequently....... Quote Link to comment Share on other sites More sharing options...
Andreas Posted May 17, 2011 Share Posted May 17, 2011 After alot of research, I am going with "vortecpro". Mark has a stellar reputation nationwide. Here is my unit. 467 517 HP 564 TQ 9.1 compression Excellent muscle car engine replacement, excellent vacuum, very street friendly Dyno tested $4995.00 Any more detailed specs on that engine? If you decide not to wait for your engine, you should consider the 454 GM crate engines. Ian posted the ZZ454, there is also the 454 HO, which I have in my Monte. They might look expensive at first, but consider that they have a NEW 4-bolt block and all forged internals & roller camshaft! Quote Link to comment Share on other sites More sharing options...
ScottNM Posted May 17, 2011 Author Share Posted May 17, 2011 I talked to Mark today. He is working 7 days/wk to keep up with demand. He personally does the work. He said 4-6 weeks. I just know he uses stuff like scat cranks, forged pistons etc. Quote Link to comment Share on other sites More sharing options...
CrazyDavey Posted May 18, 2011 Share Posted May 18, 2011 I know Mark a bit and he builds some good stuff. He's pretty good at matching things up on combo's. He's really well known for the re-work he does on GM iron heads.... Quote Link to comment Share on other sites More sharing options...
