Monteman1971 Posted July 5, 2011 Share Posted July 5, 2011 My aluminum heads are on and now I'm determining what length push rods I need. I did the trick with the marker and this is what I got....is this good, bad or indifferent? Do I need longer or shorter...thanks all. Steve Quote Link to comment Share on other sites More sharing options...
Mo's70MCs Posted July 5, 2011 Share Posted July 5, 2011 Looks like proper rocker arm geometry. It's right on the money from here. What cyl did you use? Just that it looks like #1.. Where the engine gurus when you need them? Quote Link to comment Share on other sites More sharing options...
Monteman1971 Posted July 5, 2011 Author Share Posted July 5, 2011 Thanks Rod..that's number 1. Quote Link to comment Share on other sites More sharing options...
Mo's70MCs Posted July 5, 2011 Share Posted July 5, 2011 you get them dialed in? Did you have to get an adjusting push rod? or did you get lucky...can't play with luck..you know. Quote Link to comment Share on other sites More sharing options...
Monteman1971 Posted July 6, 2011 Author Share Posted July 6, 2011 Spoke with my engine builder, on my way home I'm going to pick up a set of "lash caps". They will raise the rocker to the middle of the valve. Mike had run them when he was using the heads and thought I might need them as well. I'll install and do the test again but I should be perfect. Quote Link to comment Share on other sites More sharing options...
black07ss Posted July 6, 2011 Share Posted July 6, 2011 Spoke with my engine builder, on my way home I'm going to pick up a set of "lash caps". They will raise the rocker to the middle of the valve. Mike had run them when he was using the heads and thought I might need them as well. I'll install and do the test again but I should be perfect. Perfect is good enough Steve Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted July 6, 2011 Share Posted July 6, 2011 that's a nice pattern, narrow not wide and almost centered Quote Link to comment Share on other sites More sharing options...
Mo's70MCs Posted July 6, 2011 Share Posted July 6, 2011 I thought the same..it's pretty dead on. You going with anything special.. valve train related?.. Quote Link to comment Share on other sites More sharing options...
Monteman1971 Posted July 7, 2011 Author Share Posted July 7, 2011 It's all roller...I think it's pretty special...lol. Actually I spoke with Mike last night, it looks good the way it is so I will probably just put it together. I did speak with my engine builder and he offered to come take a look tonight to be sure. Quote Link to comment Share on other sites More sharing options...
Mo's70MCs Posted July 7, 2011 Share Posted July 7, 2011 It's all roller...I think it's pretty special...lol. what ss, aluminum, steel, give us more. Those eddy heads need something fancy. Quote Link to comment Share on other sites More sharing options...
Heckeng Posted July 7, 2011 Share Posted July 7, 2011 Looks good to me too. Is that stock length that you checked? Quote Link to comment Share on other sites More sharing options...
Monteman1971 Posted July 8, 2011 Author Share Posted July 8, 2011 With the roller the push rods are just about .050 shorter. My builder came by last night and we tested with the lash caps and it brought it dead center. The heads have stainless valves 2.25 and 1.88 (that's as big as they get), they have been polished up real nice inside and also port matched to the Air Gap manifold.... I had purchased all this from Mike (Mike 57) over the winter. He gave me a sweet deal on everything and has also been my "tech support"....lol Quote Link to comment Share on other sites More sharing options...
speedfreak71 Posted July 11, 2011 Share Posted July 11, 2011 .050 was they same measurement for both intake and exhaust? Quote Link to comment Share on other sites More sharing options...
Monteman1971 Posted July 19, 2011 Author Share Posted July 19, 2011 Sorry for the delay but yes....installed the lash caps on all 16 valves. Quote Link to comment Share on other sites More sharing options...
