Power Steering Noise
Xxyyzz
So my power steering has always made a slight whine /hum at full lock. All my cars do and its normal. I just replaced my power steering belt, and now it makes a loud screech at full lock. Any ideas?
-Mark
When you go full lock the pump will top out its pressure so you don't want to do that for very long-very hard on the pump. When you have to make a hard turn it's always best to back off a bit untill you no longer feel the pump straining. Having said all of that the belt is probably slipping and needs to be tightened. David
