Xxyyzz Posted April 1, 2012 Share Posted April 1, 2012 So my power steering has always made a slight whine /hum at full lock. All my cars do and its normal. I just replaced my power steering belt, and now it makes a loud screech at full lock. Any ideas? -Mark Quote Link to comment Share on other sites More sharing options...
bobsmc Posted April 2, 2012 Share Posted April 2, 2012 the belt should be tighter? or its not the correct width. Quote Link to comment Share on other sites More sharing options...
zmanabba Posted April 2, 2012 Share Posted April 2, 2012 When you go full lock the pump will top out its pressure so you don't want to do that for very long-very hard on the pump. When you have to make a hard turn it's always best to back off a bit untill you no longer feel the pump straining. Having said all of that the belt is probably slipping and needs to be tightened. David Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted April 2, 2012 Share Posted April 2, 2012 Quote Link to comment Share on other sites More sharing options...
Xxyyzz Posted April 2, 2012 Author Share Posted April 2, 2012 will do, easy enough Quote Link to comment Share on other sites More sharing options...
Mo's70MCs Posted April 2, 2012 Share Posted April 2, 2012 A shot of belt dressing wouldn't hurt it either. Quote Link to comment Share on other sites More sharing options...
Rob Peters Posted April 3, 2012 Share Posted April 3, 2012 The pump will also squeal if the fluid level is too low. Quote Link to comment Share on other sites More sharing options...
Xxyyzz Posted April 3, 2012 Author Share Posted April 3, 2012 belt dressing was already done, thanks rod. I will check the level, thanks rob. Quote Link to comment Share on other sites More sharing options...
Leghome Posted April 3, 2012 Share Posted April 3, 2012 Make sure your check the fluid while it is hot. Quote Link to comment Share on other sites More sharing options...
Xxyyzz Posted April 3, 2012 Author Share Posted April 3, 2012 i did not know that, thank you. Quote Link to comment Share on other sites More sharing options...
