leelee Posted November 4, 2012 Share Posted November 4, 2012 There are two very thin wires comming out beside the speedometor. Can you tell me what they are for and what they hook up too. I used to know but can't remember. Link to comment Share on other sites More sharing options...
monte70car Posted November 4, 2012 Share Posted November 4, 2012 What year is the car in question? One thing running in my mind is the door chime when the key is in the switch and the door is open. Link to comment Share on other sites More sharing options...
Sam (Bones) Posted November 4, 2012 Share Posted November 4, 2012 and what color are they? Link to comment Share on other sites More sharing options...
wallaby Posted November 4, 2012 Share Posted November 4, 2012 it's not the puppet strings for the PRNDL is it? Link to comment Share on other sites More sharing options...
stangeba Posted November 4, 2012 Share Posted November 4, 2012 Like these? PRND21 control wires Link to comment Share on other sites More sharing options...
leelee Posted November 4, 2012 Author Share Posted November 4, 2012 Yes, that is what it is the PRNDL but it doesn't have the little plate on them. How can i fix that? Oh Yeah it's a 1972 Link to comment Share on other sites More sharing options...
monte70car Posted November 4, 2012 Share Posted November 4, 2012 I was going to say 10lbs fishing line works, but since you don't have the plate that screws on to the column it might not work. Usual that breaks when you forget to remove the screw that holds the plate to the column, it could be the plate is still on the column and in that case the fish line will work. Link to comment Share on other sites More sharing options...
leelee Posted November 5, 2012 Author Share Posted November 5, 2012 Thank you very much. I will check and see if it is still on the column. Y'all are a lot of help. Link to comment Share on other sites More sharing options...
D.E Posted November 5, 2012 Share Posted November 5, 2012 I forgot to unscrew when I remove column but it just pulled out of plate so I took small bit opened up holder and was able to recrimp wire in holder,Was lucky Link to comment Share on other sites More sharing options...
bigtankjones Posted November 6, 2012 Share Posted November 6, 2012 I forgot to unscrew when I remove column but it just pulled out of plate so I took small bit opened up holder and was able to recrimp wire in holder,Was lucky Good Deal. Link to comment Share on other sites More sharing options...
stangeba Posted November 6, 2012 Share Posted November 6, 2012 I had my entire dash out three times in the past 29 years and almost forgot each time! Happy it's fixed. Bruce Link to comment Share on other sites More sharing options...
