1970mcss Posted March 19, 2018 Share Posted March 19, 2018 I'm ready to replace the hockey stick mouldings on my 70. It looks like the bumper has to be lowered or removed. So is there a easy way to replace them or a way to lower the bumper enough to get the job done. If the bumper has to come off, how diffacult is it. Quote Link to comment Share on other sites More sharing options...
Canuck Posted March 19, 2018 Share Posted March 19, 2018 I believe you would need to remove the bumper to be able to access the screws holding that trim in place. Quote Link to comment Share on other sites More sharing options...
cny first gen 71 Posted March 19, 2018 Share Posted March 19, 2018 To replace the center peice yes the bumper has to be removed but its really not that hard to do. just remember the back up lights and lic. plate light have to come off too. the two end peices you get from inside the trunk if I remember correctly. Quote Link to comment Share on other sites More sharing options...
1970mcss Posted March 19, 2018 Author Share Posted March 19, 2018 I'm replacing the the two end pieces, those screws seem to be screwed from the bottom, is that correct? Quote Link to comment Share on other sites More sharing options...
cny first gen 71 Posted March 19, 2018 Share Posted March 19, 2018 I'm pretty sure they go into trunk. Check the back side from inside the trunk you should find the studs sticking through. Quote Link to comment Share on other sites More sharing options...
sredmyer Posted March 19, 2018 Share Posted March 19, 2018 Pretty sure the ones on the 71 are accessed from inside the trunk but on the 70 they are outside and you have to at least loosen the bumper and let it down a bit. Quote Link to comment Share on other sites More sharing options...
1970mcss Posted March 19, 2018 Author Share Posted March 19, 2018 It does look like they screw from the outside. I'll try to loosen the bumper and drop it a bit. Do I just loosen then bracket to frame bolts? Thanks Quote Link to comment Share on other sites More sharing options...
Canuck Posted March 19, 2018 Share Posted March 19, 2018 Yes loosen the bolts that hold the brackets to the frame. 4 inside the trunk, 4 under the car and 2 above the license plate. Quote Link to comment Share on other sites More sharing options...
Rock Posted March 19, 2018 Share Posted March 19, 2018 I have a 70 and I was able to remove the tail light extensions bolts and get enough room to remove the screws that are on the underside of the hockey sticks. I suggest using some masking tape around the area as not to scratch the paint. Quote Link to comment Share on other sites More sharing options...
cny first gen 71 Posted March 19, 2018 Share Posted March 19, 2018 Didn't know 70 was different sorry. Quote Link to comment Share on other sites More sharing options...
1970mcss Posted March 19, 2018 Author Share Posted March 19, 2018 I have a 70 and I was able to remove the tail light extensions bolts and get enough room to remove the screws that are on the underside of the hockey sticks. I suggest using some masking tape around the area as not to scratch the paint. Rock, where do you recommend putting tape??? Quote Link to comment Share on other sites More sharing options...
Rob Peters Posted March 20, 2018 Share Posted March 20, 2018 Rock, where do you recommend putting tape??? I think what he is talking about is putting some tape on any painted surfaces or chrome that may get scratched from the shaft of the screwdriver rubbing against any delicate surfaces. rob Quote Link to comment Share on other sites More sharing options...
Rock Posted March 20, 2018 Share Posted March 20, 2018 Rock, where do you recommend putting tape??? I don’t think you can pull the extension off completely but you can pull it out far enough to get at the screws. I taped around the area where the extension bolts onto. Can’t be to careful. Quote Link to comment Share on other sites More sharing options...
Paul Bell Posted March 20, 2018 Share Posted March 20, 2018 On a 1970 car, the rear valance outer hockey stick moldings have screws through them into the bottom lip of the valance. You need to drop the rear bumper to access them. The same is for the long center molding. Â The same holds true on a 1971 car EXCEPT: Â The SS hockey sticks are studded and are nutted from inside. 1 Quote Link to comment Share on other sites More sharing options...
1970mcss Posted March 20, 2018 Author Share Posted March 20, 2018 Thanks for all the advice, I'm going to give it a look this weekend, I'll keep you posted, thanks again Quote Link to comment Share on other sites More sharing options...
1970mcss Posted March 21, 2018 Author Share Posted March 21, 2018 Success, I couldn't wait until the weekend. I got the bumper off which was easier than I thought it would be. It was also easy because someone before me left off the bolts above the licence plate and two lower bolts. I also had to remove one of the quarter exstenions to install a speed nut for one of the moulding screws. While i have the bumper off I'm going to replace the bumper guard cushions and clean things up. I'm learning so much about this car. Thanks for all the input... 3 Quote Link to comment Share on other sites More sharing options...
