TommySS454 Posted July 5 Share Posted July 5 Looking for some advice here. I'm test fitting the rear quarter and wheel houses. The outer wheel house lip is not mating up with the quarter lip. How much space do you guys have? I'm guessing my wheel house lip is a half inch above the quarter panel lip. The passenger side is factory and has about a quarter inch of space. What's acceptable and normal here? Thanks Quote Link to comment Share on other sites More sharing options...
TommySS454 Posted July 6 Author Share Posted July 6 This is a picture of what I'm talking about. Taken from inside the wheel well. Quote Link to comment Share on other sites More sharing options...
Glen Posted July 6 Share Posted July 6 I see the problem. It’s the “MADE IN TAIWAN” part of your quarter panel. Not trying to be a JO, but aftermarket parts suck. I know OE sheet-metal for our Montes is few and far between and expensive when located, but it’s usually well worth it in the grand scheme of things. I even paid for an original Ford front bumper cover for my ‘08 Crown Vic. I wanted it to fit right, didn’t mind paying a little bit more for it. Good luck to ya. 1 Quote Link to comment Share on other sites More sharing options...
TommySS454 Posted July 6 Author Share Posted July 6 AMD is the best option available for aftermarket panels today. Not much of a choice. But thanks for the useful advice. Quote Link to comment Share on other sites More sharing options...
72RustBucket Posted July 14 Share Posted July 14 I just got done dealing with this. I am no expert so take everything with a grain of salt. I had AMD outer wheel well and amd quarter, same side of the car. I was initially having the same problem. Do you have the wheel well welded in yet? If you can still move things around it obviously helps a lot. How is the quarter hanging? Do all body lines match up etc? Part of my problem was the quarter wasn't quite hanging right. One of my other issues was not prepping between removing my old and installing my new good enough. Small burs or bends/imperfections along the mating surfaces etc can really make it difficult to slide the pieces into the place they need to be. I had some junking near the rocker panels where the front of the wheel well slides into. I basically couldnt rotate the wheel well counter clockwise enough, which because of the shape of the wheel arch threw everything off enough to not match up. That being said, there WILL be a small gap in some places along the wheel well/quarter lip. There well also be places where it meets up 100%. Take your time, check everything a bunch of times. I probably hung and rehung my quarter several dozen times... 1 Quote Link to comment Share on other sites More sharing options...
TommySS454 Posted July 30 Author Share Posted July 30 (edited) So I finally got the gap closed up and the wheel houses are welded in. The quarter is 95% welded on except the rear and around the rear window. Going to get the rear window filler panel put in before I button that up. I ended up removing about a quarter inch section of the front of the outer wheel house where it meets the rocker panel. That allowed me to rotate the wheel house slightly. That helped the gap. After that it was lots of test fitting and using clamps to get it in position. Im pretty happy with it. I talked to a body man that has worked on several A-bodies over the years and he says the wheel houses didnt fit very good straight from the factory. Ill try to get some pictures up. Edited July 31 by TommySS454 Pictures 2 Quote Link to comment Share on other sites More sharing options...
Montemedic Posted August 11 Share Posted August 11 Looks good Tommy !!! Quote Link to comment Share on other sites More sharing options...
Glen Posted Friday at 10:34 PM Share Posted Friday at 10:34 PM Well done. I was I had even remedial body skills. 1 Quote Link to comment Share on other sites More sharing options...
cny first gen 71 Posted Friday at 11:51 PM Share Posted Friday at 11:51 PM Great job, way above my skill level but I'd probably be dumb enough to try it lol. I'm sure it would take me twice as long and mess it up a couple times but would be proud when it's done. Quote Link to comment Share on other sites More sharing options...
