rsorg Posted November 25, 2023 Share Posted November 25, 2023 hi , i am thinking of having brake boosters do my restoration on my booster has anyone here used them there address is ,san luis obispo cal. thanks roger Quote Link to comment Share on other sites More sharing options...
Chevy Dave Posted November 25, 2023 Share Posted November 25, 2023 I have used Power Brake Booster Exchange, located in Lynwood, WA. They did good work for me several years ago when they were located in Portland, OR. The original owner retired and it was taken over by a new guy in Washington. Quote Link to comment Share on other sites More sharing options...
jft69z Posted November 26, 2023 Share Posted November 26, 2023 8 hours ago, rsorg said: hi , i am thinking of having brake boosters do my restoration on my booster has anyone here used them there address is ,san luis obispo cal. thanks roger Yes, They did mine. Every part of the deal was top notch, you won't be disappointed. Quote Link to comment Share on other sites More sharing options...
TheBMan Posted November 26, 2023 Share Posted November 26, 2023 @rsorg Is there a benefit to restoring your current booster rather than purchasing a replacement? There are restoration-correct replacements available in the aftermarket. They have the correct gold-colored finish and 'delco moraine' stamping. Quote Link to comment Share on other sites More sharing options...
jft69z Posted November 26, 2023 Share Posted November 26, 2023 1 hour ago, TheBMan said: @rsorg Is there a benefit to restoring your current booster rather than purchasing a replacement? There are restoration-correct replacements available in the aftermarket. They have the correct gold-colored finish and 'delco moraine' stamping. There IS a difference. Most of the aftermarket boosters are made offshore, even though they have the Delco stamp.. I'll add a link here on how to ID them, but suffice to say, Mike at Brakeboosters.com will not go anywhere near those things. You can either send yours to them, or they'll provide you with a genuine Gm booster. After reading the below info, every time you see a booster at a show, you'll immediately spot a repro booster by the sharp, triangle shaped stamping on the face of the booster. 😁 Scroll about half way down the page: https://www.brakeboosters.com/brake-boosters-history 1 Quote Link to comment Share on other sites More sharing options...
Dtret Posted November 26, 2023 Share Posted November 26, 2023 If you are restoring you want as many “ correct parts “ as possible. Most times it’s more expensive but it is correct for the car. Some of the aftermarket parts are not as good as the original ones, so that’s always a thought too. 2 Quote Link to comment Share on other sites More sharing options...
rsorg Posted November 26, 2023 Author Share Posted November 26, 2023 i have decided to go with brakeboosters ,he is going to restore my original booster thanks,roger 1 Quote Link to comment Share on other sites More sharing options...
