MC1of80 Posted February 17 Posted February 17 Gears, posi unit, install kit with bearings, differential fluid, posi additive (if not using a trutrac) ,money, someone to set it all up correctly. 5 Quote
Scott S. Posted February 17 Posted February 17 And a type 3 carrier.... 2.73 gears are housed in a type 2. 3 Quote
Rich 71 Posted February 17 Author Posted February 17 thanks the carrier was what i was needing to know Quote
DragCat Posted February 18 Posted February 18 4 hours ago, Scott S. said: And a type 3 carrier.... 2.73 gears are housed in a type 2. I found that out the hard way 🤣 1 Quote
DragCat Posted February 18 Posted February 18 6 hours ago, MC1of80 said: Gears, posi unit, install kit with bearings, differential fluid, posi additive (if not using a trutrac) ,money, someone to set it all up correctly. X2 on the posi additive 3 Quote
DragCat Posted February 18 Posted February 18 Luckily I had experienced help when I did mine I upgraded the axels at the same time 4 Quote
MC1of80 Posted February 18 Posted February 18 2 hours ago, DragCat said: X2 on the posi additive Not if you go with the Detroit trutrac. No posi additive needed. 4 Quote
Scott S. Posted February 18 Posted February 18 I found it was easier to do it with the differential out of the car. 4 Quote
Grant MacPherson Posted February 19 Posted February 19 Not to question your choice, changed my 2.56 to 3.42, was determined I wanted 3.73 but the shop that did it told me every past customer he had put 3.73s in were not happy. I am glad I went with his recommendation, huge difference on take off and still able to cruise at 70 mph. 4 Quote
Scott S. Posted February 19 Posted February 19 16 hours ago, Grant MacPherson said: Not to question your choice, changed my 2.56 to 3.42, was determined I wanted 3.73 but the shop that did it told me every past customer he had put 3.73s in were not happy. I am glad I went with his recommendation, huge difference on take off and still able to cruise at 70 mph. Even better if you switch to an overdrive transmission..... 1 Quote
420ponies Posted February 19 Posted February 19 If going this route, I suggest you get new bearings , seals also. Are you going to give it a try or find someone to set it up for you? I have a Yukon Posi-traction unit in mine. I also upgraded to Moser Street axles. 3 Quote
