Rich 71 Posted February 17 Share Posted February 17 what will i need to make it work Quote Link to comment Share on other sites More sharing options...
MC1of80 Posted February 17 Share Posted February 17 Gears, posi unit, install kit with bearings, differential fluid, posi additive (if not using a trutrac) ,money, someone to set it all up correctly. 5 Quote Link to comment Share on other sites More sharing options...
Scott S. Posted February 17 Share Posted February 17 And a type 3 carrier.... 2.73 gears are housed in a type 2. 3 Quote Link to comment Share on other sites More sharing options...
Rich 71 Posted February 17 Author Share Posted February 17 thanks the carrier was what i was needing to know Quote Link to comment Share on other sites More sharing options...
DragCat Posted February 18 Share Posted February 18 4 hours ago, Scott S. said: And a type 3 carrier.... 2.73 gears are housed in a type 2. I found that out the hard way 🤣 1 Quote Link to comment Share on other sites More sharing options...
DragCat Posted February 18 Share Posted February 18 6 hours ago, MC1of80 said: Gears, posi unit, install kit with bearings, differential fluid, posi additive (if not using a trutrac) ,money, someone to set it all up correctly. X2 on the posi additive 3 Quote Link to comment Share on other sites More sharing options...
DragCat Posted February 18 Share Posted February 18 Luckily I had experienced help when I did mine I upgraded the axels at the same time 4 Quote Link to comment Share on other sites More sharing options...
MC1of80 Posted February 18 Share Posted February 18 2 hours ago, DragCat said: X2 on the posi additive Not if you go with the Detroit trutrac. No posi additive needed. 4 Quote Link to comment Share on other sites More sharing options...
Scott S. Posted February 18 Share Posted February 18 I found it was easier to do it with the differential out of the car. 4 Quote Link to comment Share on other sites More sharing options...
Grant MacPherson Posted February 19 Share Posted February 19 Not to question your choice, changed my 2.56 to 3.42, was determined I wanted 3.73 but the shop that did it told me every past customer he had put 3.73s in were not happy. I am glad I went with his recommendation, huge difference on take off and still able to cruise at 70 mph. 4 Quote Link to comment Share on other sites More sharing options...
Scott S. Posted February 19 Share Posted February 19 16 hours ago, Grant MacPherson said: Not to question your choice, changed my 2.56 to 3.42, was determined I wanted 3.73 but the shop that did it told me every past customer he had put 3.73s in were not happy. I am glad I went with his recommendation, huge difference on take off and still able to cruise at 70 mph. Even better if you switch to an overdrive transmission..... 1 Quote Link to comment Share on other sites More sharing options...
420ponies Posted February 19 Share Posted February 19 If going this route, I suggest you get new bearings , seals also. Are you going to give it a try or find someone to set it up for you? I have a Yukon Posi-traction unit in mine. I also upgraded to Moser Street axles. 3 Quote Link to comment Share on other sites More sharing options...
