Dtret Posted March 8 Share Posted March 8 Please reeducate me here. Rear upper shock mounting. I seem to remember the bolts have a speed nut slid into the frame slot , but I’m seeing bolts, washers and nuts. Obviously the nuts are a PITA. Which is correct? AMK sells b,n &w and it’s also what was on the 72. Quote Link to comment Share on other sites More sharing options...
jft69z Posted March 8 Share Posted March 8 Assembly manuals show nuts & bolts. Service manuals show the same. Same on my 72 as well. 2 Quote Link to comment Share on other sites More sharing options...
Dtret Posted March 8 Author Share Posted March 8 29 minutes ago, jft69z said: Assembly manuals show nuts & bolts. Service manuals show the same. Same on my 72 as well. Ya. I guess I could have done a little self research. lol. Lazy I guess. Thanks. 1 3 Quote Link to comment Share on other sites More sharing options...
cny first gen 71 Posted March 8 Share Posted March 8 Yup bolts and nuts. We used to use 5/16x1 inch course thread drop them down through the holes it's much easier than putting the nut on the top. 2 Quote Link to comment Share on other sites More sharing options...
Dtret Posted March 8 Author Share Posted March 8 Done. Bolts up, nuts on top. Looks like I will be changing the coil springs again. Do not like the height at all. Pic to follow as I need to do the front shocks yet. Not doing front coils at this time so the rake should be pretty interesting. 2 Quote Link to comment Share on other sites More sharing options...
Dtret Posted March 8 Author Share Posted March 8 Not as bad as I thought once I got the front off jack stands. New front coils should balance it out. I’ll clean the new white walls later. 6 Quote Link to comment Share on other sites More sharing options...
cny first gen 71 Posted March 8 Share Posted March 8 Yea bolts up nuts on top is the way they did it from factory but when your working flate rate or commission go the easy way. 2 Quote Link to comment Share on other sites More sharing options...
Marks71 Posted March 8 Share Posted March 8 I think the stance looks fine. Won’t those new coils settle a little anyway? 1 Quote Link to comment Share on other sites More sharing options...
Leghome Posted March 8 Share Posted March 8 5 hours ago, Dtret said: Not as bad as I thought once I got the front off jack stands. New front coils should balance it out. I’ll clean the new white walls later. I thought you were trying to start a new trend with blue walls 1 Quote Link to comment Share on other sites More sharing options...
Dtret Posted March 9 Author Share Posted March 9 2 hours ago, Leghome said: I thought you were trying to start a new trend with blue walls Karen came home and said the new tires look like crap. The blue clashes with the green. lol. 3 Quote Link to comment Share on other sites More sharing options...
Rob Peters Posted March 9 Share Posted March 9 I'm Lovin the White Wall to be. rob 1 Quote Link to comment Share on other sites More sharing options...
