kc8oye Posted June 7, 2010 Share Posted June 7, 2010 if you mount the tach in the right place on the column, it won't move. as for the monster tach's... AutoGauge does make an 8000 rpm monster tach too. i like the 5" tach because I can read it at a glance.. when I'm busy driving. where it's mounted, it's right in the corner of my line of sight out the window so I only have to glance a little off to the side to see it Quote Link to comment Share on other sites More sharing options...
wallaby Posted June 7, 2010 Author Share Posted June 7, 2010 Yea....I know. If I clamp onto the column closer to the steering wheel it won't rotate when I shift gears. The problem is that to get the tach to reside in front of the clock area, I'd have to use some long, curved bracket to get around the shifter that DOES move when I shift. I don't want to drill any holes. Yesterday I made myself a block that matches the curve of the column on the bottom, and matches the curve of the Tach on the top. (small part, big labor). I can mount the tach directly to the column now, without using a big hose clamp....if I decide that's what I want to do. I found that if I put it a little left of center, it only blocks my view of the brake light. The speedo, gas guage and PRNDL window are in clear sight. Now I just need to decide if my arm is going to be in the way. LOL I have found that my method of holding the steering wheel blocks even the speedometer. I have to kinda release my grip on the wheel and rotate my hand to view my speed. (sound familiar?) Let's see...my left arm rests in the open window, and my right arm holds the wheel at about the 11 O'clock position... That stupid arm of mine blocks my view of a lot of dashboard. It's amazing how many factors come into play when doing a "simple" tachometer install. Next time I'll just mount it to the front of my helmet. LOL Quote Link to comment Share on other sites More sharing options...
wallaby Posted June 8, 2010 Author Share Posted June 8, 2010 All done. I relocated it to the more traditional location on the steering column. Here is the part I made to make it possible: Here's how it looked on my mock-up: And here it is installed: Quote Link to comment Share on other sites More sharing options...
kc8oye Posted June 8, 2010 Share Posted June 8, 2010 well how boring is that? LOL j/k.. looks good mark. i plan to race time trials and auto-x with the monte.. so I have other criteria in mind sometiems that's why the tach is where it's at.. so I can see it out of the corner of my eye.. there is no missing that shift light Quote Link to comment Share on other sites More sharing options...
TN454Monte Posted June 13, 2010 Share Posted June 13, 2010 How's it mount to the column Mark? Very cool looking and Neat idea, just curious how you attach it. Quote Link to comment Share on other sites More sharing options...
Nygel Posted June 13, 2010 Share Posted June 13, 2010 Quote: How's it mount to the column Mark? I was wondering the same. Nygel Quote Link to comment Share on other sites More sharing options...
CrazyDavey Posted June 13, 2010 Share Posted June 13, 2010 sorta like this....but not.... here's a shot of the back... Quote Link to comment Share on other sites More sharing options...
Chevyss Posted June 14, 2010 Share Posted June 14, 2010 That's cute Davey. Quote Link to comment Share on other sites More sharing options...
CrazyDavey Posted June 14, 2010 Share Posted June 14, 2010 That's cute Davey. thanks Royce..I was going for cute..... Quote Link to comment Share on other sites More sharing options...
Mikstudie Posted June 16, 2010 Share Posted June 16, 2010 Got one dont use it.when racing if you got the guy beat shift sooner if not hold the pedal to the floor until car stops going faster then shift (no brainer) Mine is mounted under ash tray area like Tims all it takes is a glance dont need to stare at it(it's called multi-tasking) Quote Link to comment Share on other sites More sharing options...
Chevyss Posted June 17, 2010 Share Posted June 17, 2010 That's what I used to do Mike. Just run it in gear till the lifters float and shift. It just looks cool to have that 5" gauge hanging off you dash. Quote Link to comment Share on other sites More sharing options...
Winston Wolf Posted June 17, 2010 Share Posted June 17, 2010 I would have used this: Clock to Tach Conversion But I like the factory look. Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted June 18, 2010 Share Posted June 18, 2010 I have that from shiftworks $134.50 works great Quote Link to comment Share on other sites More sharing options...
kc8oye Posted June 18, 2010 Share Posted June 18, 2010 i have a 1/4" thick bar that comes right thru the front of the dash, and goes back to the firewall to mount my tach also made for a good place to hang my naroow band o2 gauge Quote Link to comment Share on other sites More sharing options...
Andy's Auto Posted June 18, 2010 Share Posted June 18, 2010 I just put a Shiftworks cocersion tach in my 68 Shovelle and it do look pretty. Andy Quote Link to comment Share on other sites More sharing options...
Chevyss Posted June 19, 2010 Share Posted June 19, 2010 Attached the 5" Auto-Meter to the left pillar. Not a good spot, but until I work something out it will stay there. It's awful heavy for that, is there some type of a mount that I could use for the middle of the dash??? Thanks in advance Quote Link to comment Share on other sites More sharing options...
wallaby Posted June 20, 2010 Author Share Posted June 20, 2010 Oh...yea, I used that heavy duty double stick tape like they use for wheel weights and side trim. No holes drilled, and no giant hose clamp! Quote Link to comment Share on other sites More sharing options...
kc8oye Posted June 21, 2010 Share Posted June 21, 2010 chevyss: you can do like i did 1/4" thick, 1" wide steel bar attached to the firewall, comes thru a small hole in the face of the dash and my 5" tach sits on that. Quote Link to comment Share on other sites More sharing options...
rah72(Rick) Posted June 23, 2010 Share Posted June 23, 2010 Many moons ago when I had the first monte. I had a Tach mounted towards the right fside of the col towards the clock. It was not as large as some of the ones I see on here. I had to work it on there a little but after a few trys got it too sit right so I could see it and didn't block the key or the col shifter. Quote Link to comment Share on other sites More sharing options...
Chevyss Posted June 25, 2010 Share Posted June 25, 2010 I remember I saw someone who makes a mount that goes in the center of the dash. Just can't remember who. Does anyone know anyone who makes something. Quote Link to comment Share on other sites More sharing options...
GregC Posted August 3, 2010 Share Posted August 3, 2010 I finally installed Shiftworks Tach to replace my non-op clock. It was a total pain to take that dash apart just to get to the instrument cluster. But it's worth it to have something functional on the cluster. Now only if my turn signal lights worked. I'm not looking forward to tearing it apart again just to put in a new circuit board. Quote Link to comment Share on other sites More sharing options...
