maddmann313 Posted October 21, 2010 Share Posted October 21, 2010 A friend of mine said that he had a base plate for my holley but the butterflies were drill out... what are these and what would they do to the carb? Quote Link to comment Share on other sites More sharing options...
kc8oye Posted October 21, 2010 Share Posted October 21, 2010 it's common to drill a small hole thru the throttle butterflies to help an engine with a big cam idle a little better by letting mroe air through so you can close the butterflies back down to where the idle ajustment screws actually work. Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted October 21, 2010 Share Posted October 21, 2010 Quote Link to comment Share on other sites More sharing options...
maddmann313 Posted October 21, 2010 Author Share Posted October 21, 2010 But if i dont have a big cam... And could you post a pic showing were the butterflies and because i may be able to use that base plate for parts Quote Link to comment Share on other sites More sharing options...
kc8oye Posted October 21, 2010 Share Posted October 21, 2010 here ya go. the two holes in the center are for attaching the butterfly. the 3rd hole on it's own near the bottom is the extra drilled hole. these are for a quadrajet, but it's the same thing. Quote Link to comment Share on other sites More sharing options...
maddmann313 Posted October 21, 2010 Author Share Posted October 21, 2010 Oh ok well then i could just buy the new butterflies and it should be okay! Quote Link to comment Share on other sites More sharing options...
wallaby Posted October 21, 2010 Share Posted October 21, 2010 Or you can solder them closed. Quote Link to comment Share on other sites More sharing options...
amsterdam84 Posted October 21, 2010 Share Posted October 21, 2010 Would JB Weld work in those holes? Quote Link to comment Share on other sites More sharing options...
Winston Wolf Posted October 22, 2010 Share Posted October 22, 2010 Try a bigger cam that needs them. I would just leave them. Adjust your idle mixture screws with a vaccum gauge and set the idle speed correctly. As long as the butterflies are in a correct position on the transfer slot after doing that you will be fine. The holes will most likely not even be noticed. Quote Link to comment Share on other sites More sharing options...
Andy's Auto Posted October 22, 2010 Share Posted October 22, 2010 I agree with the Wolfinator. Bolt it on and back the idle speed screw out and see if it will idle where you need it. It is only a problem if the idle is too high. And NOOO to the JB weld thing. If the crud falls in the intake there will be hell to pay. Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted October 22, 2010 Share Posted October 22, 2010 I agree with the Wolfinator. Bolt it on and back the idle speed screw out and see if it will idle where you need it. It is only a problem if the idle is too high. And NOOO to the JB weld thing. If the crud falls in the intake there will be hell to pay. Quote Link to comment Share on other sites More sharing options...
kc8oye Posted October 22, 2010 Share Posted October 22, 2010 a) you can't "Solder" aluminum. JB weld is a bad idea.. it will just get brittle and fall out. I doubt it would be enough to do any damage, but you never know. Quote Link to comment Share on other sites More sharing options...
