vince Posted March 30, 2011 Share Posted March 30, 2011 I have a solid 6 blade fan bolted straight to the water pump. One if the blades is slightly bent, Can this bent blade cause a vibration issue when I reach 60-65 mph? I ruled out the following components, front bearings(new inner and outer) wheel alignment(had it checked twice) bent drive shaft(sent out to be balanced) tire balance (checked out by discount tire) I am running out of options, I only feel it when I reach higher speeds. Quote Link to comment Share on other sites More sharing options...
stangeba Posted March 30, 2011 Share Posted March 30, 2011 I would think a fan out of balance would cause a vibration at a certain RPM in all 3 (or 4) gears. It would be a bit of work but remove the fan blade and drive it. It shouldn't overheat if you don't get stuck in traffic. Bruce Quote Link to comment Share on other sites More sharing options...
502ci Posted March 30, 2011 Share Posted March 30, 2011 It's possible. Try driving at 65 and when you feel the vibration put the car in neutral, the RPM's will drop way down along with the fan speed. If the vibration goes away then it is the fan...or could be something else unrelated that is in your driveline. Quote Link to comment Share on other sites More sharing options...
CrazyDavey Posted March 30, 2011 Share Posted March 30, 2011 It's possible. Try driving at 65 and when you feel the vibration put the car in neutral, the RPM's will drop way down along with the fan speed. If the vibration goes away then it is the fan...or could be something else unrelated that is in your driveline. Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted March 30, 2011 Share Posted March 30, 2011 free revving the engine in park will give you the answer, if it doesn't do it in park, it's not the engine, it's the more than likely a driveshaft angle issue with seeing everything else you already checked Quote Link to comment Share on other sites More sharing options...
vince Posted April 3, 2011 Author Share Posted April 3, 2011 Sorry for my late reply to your post. I was preoccupied with some sad news of my daughters friend being in a fatal accident. I didn't have time to log on this week. I will try the netural trick and see what happens. Sam: Could having big block front springs or Air bags in rear springs cause the issue with the drive shaft angle? Quote Link to comment Share on other sites More sharing options...
MGD72Monte Posted April 4, 2011 Share Posted April 4, 2011 As per Bruce's suggestion, it will take you 10 mins to take the fan off and then you duplicate the exact situation and rule it out for sure. Sorry to hear about the bad news. Quote Link to comment Share on other sites More sharing options...
vince Posted April 4, 2011 Author Share Posted April 4, 2011 I'll give that a try as well. thanks Quote Link to comment Share on other sites More sharing options...
Riznitch Posted April 5, 2011 Share Posted April 5, 2011 Not that it would help the vibration but, what a sweet color on that monte vince! What is the paint code on that? Quote Link to comment Share on other sites More sharing options...
vince Posted April 5, 2011 Author Share Posted April 5, 2011 Honestly I am not sure of the code but the name is Acura/Honda Fiji Blue. Quote Link to comment Share on other sites More sharing options...
