snomobeelr Posted May 19, 2012 Share Posted May 19, 2012 Having the engine rebuilt. 454, 60 over 10 to 1. Radiator is a 4 core. Did not have heating issues prior to re-doing the engine. Do I go with a Stock pump or a high volume aluminum Pump? suggestions. Thanks , Alan Quote Link to comment Share on other sites More sharing options...
Mo's70MCs Posted May 19, 2012 Share Posted May 19, 2012 brain fart!! Quote Link to comment Share on other sites More sharing options...
cudax Posted May 19, 2012 Share Posted May 19, 2012 Alan, I basically just did the same build on my now 496 and I went with a Weiand aluminum pump. Upgraded from a Procomp aluminum though they both gave me no issues in cooling the Weiand definately fit much better. The Procomp had to be ground off a little around the timing chain cover to fit properly. Mike Quote Link to comment Share on other sites More sharing options...
FASTSS454 Posted May 19, 2012 Share Posted May 19, 2012 Here is a link to the one I have on my Monte, it has given me many years of good quality service. http://www.summitracing.com/parts/EDL-8851/ Quote Link to comment Share on other sites More sharing options...
72-CLASSIC_RIDE Posted May 19, 2012 Share Posted May 19, 2012 Went with the Weiland on my 402 BB a couple years ago. No performance issues. I selected the polished aluminum Summit #9242P. Doug Quote Link to comment Share on other sites More sharing options...
CrazyDavey Posted May 19, 2012 Share Posted May 19, 2012 if you need a short one I have a factory aluminum 502 pump.... Quote Link to comment Share on other sites More sharing options...
snomobeelr Posted May 19, 2012 Author Share Posted May 19, 2012 How do I tell if I have a long or a short pump ? Thanks Davey. Hopfully be geting the Motor and putting it in a month or so. Havent had time to do anything with the car latley.. Quote Link to comment Share on other sites More sharing options...
502ci Posted May 19, 2012 Share Posted May 19, 2012 How do I tell if I have a long or a short pump ? Thanks Davey. Hopfully be geting the Motor and putting it in a month or so. Havent had time to do anything with the car latley.. Here's a basic picture of a short and long water pump... Short Long As you can see the long style (which came stock on our cars) will have all the mounting points for accessories, the short has none. My 502 came with a short style and I removed it and put my factory original one on so I could mount everything back up...painted it silver first to make it look more like aluminum though. Besides being very heavy it has worked perfectly fine, eventually I will replace it to shed some weight. Quote Link to comment Share on other sites More sharing options...
snomobeelr Posted May 20, 2012 Author Share Posted May 20, 2012 Cool thank you all.. I have the Long Pump then.. Quote Link to comment Share on other sites More sharing options...
