CKZ03 Posted January 30, 2013 Share Posted January 30, 2013 I will be installing my heater hoses soon, possibly this evening if I get a response here today. Hoping someone could measure the length of their hoses for me. I do not have my fenders or inner fender sheilds on the car currently, so I don't have anything to gauge how long they should be. From what I remember and what I see in pics the hoses should lay on the inner sheild and attached with a clamp. Just trying to get them close as possible as to where they should normally be, so a measurement would really help me out here any help would be greatly appreciated, thanks Cory 72 350 w/air Link to comment Share on other sites More sharing options...
MCfan Posted January 30, 2013 Share Posted January 30, 2013 Cory, the hose to the intake manifold is 44" and the one to the water pump is 50" on my '70 402. I believe they are routed across the passenger inner fender in a stock configuration. I replaced the heater hoses when I installed Classic Auto Air but did not change their length so I believe they are stock length, also. Link to comment Share on other sites More sharing options...
CKZ03 Posted January 30, 2013 Author Share Posted January 30, 2013 Thanks for the info I really appreciate it but I'm working on a small block 350. with ac. Pretty sure big block lenghts will measure different. I just really need to get close, I don't want too much slack & of course if I go too short that's a real issue. Link to comment Share on other sites More sharing options...
MCfan Posted January 30, 2013 Share Posted January 30, 2013 Are you using stainless braided hoses with crimped ends? If not, rubber heater hose is cheap - cut them generously to start and whack them off to fit neatly when you install them. Link to comment Share on other sites More sharing options...
cny first gen 71 Posted January 30, 2013 Share Posted January 30, 2013 48 inches to water pump 44 to manafold on my 350 sb mounted stock threw holder on inner fender well. Hope its not to late. Link to comment Share on other sites More sharing options...
CKZ03 Posted January 30, 2013 Author Share Posted January 30, 2013 Nope its not too late, thanks for the measurements, now can someone get me a few nice pics? I decided to stop and gather more info before cutting. I only want to do this once. Engine is full of coolant already and has been for a while as it has been run several times in the last year for various reasons. I had plugs where my heater hose nipples should be, now Im going back in to finish of the heater system plumbing & adding a temp gauge sensor. My fenders and inners are not on the car so the measurements really will help. I do not want to have to remove & cut and/or add length or drain out coolant again later, its kinda messy. Does anyone have any pics of their heater hose routing? THANKS Cory Link to comment Share on other sites More sharing options...
monte70car Posted January 30, 2013 Share Posted January 30, 2013 Cory I know on the 70's there is a bracket on the upper alt bracket to hold the a/c line and the hose for the water pump. Link to comment Share on other sites More sharing options...
Murphy Posted January 30, 2013 Share Posted January 30, 2013 Hey Cory, just measured my hoses, stock SBC350 w/AC and I have 39" to the manifold and 46" to the water pump. But I would take Dennis' advice if using rubber hoses, make them a couple inches longer for final adjustment. If you drain down the radiator abit you won't get any coolant spill on the motor if you need to modify hose length. Link to comment Share on other sites More sharing options...
CKZ03 Posted January 30, 2013 Author Share Posted January 30, 2013 Thanks guys for all the help here. Think I will kind of take the average out of the three measurements and roll with it, should put me in the ballpark. Thanks for the pic Murphy, nice clean & organized look on your line routings. You guys are great! Link to comment Share on other sites More sharing options...
Rob Peters Posted January 31, 2013 Share Posted January 31, 2013 I'm not sure about the lengths or the 71 and 72 but on my 70 the supply line attaches to a vacuum controlled valve and then from thos valve to the heater core. This vacuum controlles valve is mounted on the inner fender well. Rob Link to comment Share on other sites More sharing options...
Canuck Posted January 31, 2013 Share Posted January 31, 2013 I'm not sure about the lengths or the 71 and 72 but on my 70 the supply line attaches to a vacuum controlled valve and then from thos valve to the heater core. This vacuum controlles valve is mounted on the inner fender well. Rob Cory's heater control valve is threaded straight into the intake like it was in 71 Montes. Link to comment Share on other sites More sharing options...
