AndyBill402 Posted August 4, 2013 Share Posted August 4, 2013 I need to control the night lights in a number of aftermarket gauges. I thought about adding a relay for this purpose, but I'll need to find a good place to tap off for the control voltage. This is in a 72 Monte. Expertise please. Quote Link to comment Share on other sites More sharing options...
7tonemonte Posted August 4, 2013 Share Posted August 4, 2013 If they aren't LED you can tap a line off of the factory dimmer, it's been a while since I've done it. I remember it being in the gauge instructions. Hopefully someone here will chime in with more info as to which wire Quote Link to comment Share on other sites More sharing options...
monte70car Posted August 4, 2013 Share Posted August 4, 2013 When I had the Auto Meter gauges under the dash I tied them into the fuse panel in the LMP plug. Quote Link to comment Share on other sites More sharing options...
wallaby Posted August 4, 2013 Share Posted August 4, 2013 I also use the LMP plug on the fusebox. It's in the lower left corner of the box. That plug is already regulated by the dimmer in the headlight switch. However, what you'll find is that no matter how you twist the dimmer, the aftermarket gauges will be brighter than the rest of the dash lights. LOL Quote Link to comment Share on other sites More sharing options...
bigscaht Posted August 7, 2013 Share Posted August 7, 2013 yeah the LMP plug works great but they gonna always be brighter than the dash!!! Quote Link to comment Share on other sites More sharing options...
72-CLASSIC_RIDE Posted August 7, 2013 Share Posted August 7, 2013 Doug Quote Link to comment Share on other sites More sharing options...
72Ragtop Posted August 8, 2013 Share Posted August 8, 2013 If your not using the original 3-terminal connector to the original radio, try the grey wire. Quote Link to comment Share on other sites More sharing options...
