battery choice - proper size
G71
i just went to wallmart and entered the information for choosing the proper battery, it showed two sizes one being slightly larger than the other. will the larger one fit?
my battery has the "side post" mounts (flat discs)
i was just curious if this standard on our cars or if someone modified it in the past
i usually choose my batteries based on consumer reports recommendations
thank you
I'm going to say either one. I bought my last one from Les Schwab and they offered a larger case and smaller case for the same year. I selected the larger that used up entire battery box and fit. Just sat closer to radiator is all. Also a side post!
Doug
