rsorg Posted June 8, 2015 Share Posted June 8, 2015 Not sure if this is the correct forum, I took the monte for a ride after I installed my new acc carpet and dynamat, and my odometer is stuck at 95,999.9 and will not turn to 96000, it makes a clicking sound, has anybody ran into the same situation ,and if so how did you fix it. Thanks a lot Quote Link to comment Share on other sites More sharing options...
Murphy Posted June 8, 2015 Share Posted June 8, 2015 Hey Roger, almost sounds like the cable has come slightly loose from the speedometer, in the replacement of carpet & dynamat is it possible that the cable got pulled a bit? Plan A; Reach up and see if the cable is tight. Plan B; Run for it, I hate ticking sounds............. Quote Link to comment Share on other sites More sharing options...
502ci Posted June 8, 2015 Share Posted June 8, 2015 Hey Roger, almost sounds like the cable has come slightly loose from the speedometer, in the replacement of carpet & dynamat is it possible that the cable got pulled a bit? Plan A; Reach up and see if the cable is tight. Plan B; Run for it, I hate ticking sounds............. First thing I thought of also, this is the most logical answer so I would check the cable inside the car and then second check where it connects to the transmission. Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted June 8, 2015 Share Posted June 8, 2015 If the speedo is still working, then the cable is still engaged, what you hear is the odometer gears slipping Quote Link to comment Share on other sites More sharing options...
Rob Peters Posted June 9, 2015 Share Posted June 9, 2015 You alsomay have dried lubricant in the cable housing causing the cable to bind and make a ticking sound. rob Quote Link to comment Share on other sites More sharing options...
rsorg Posted June 9, 2015 Author Share Posted June 9, 2015 Yes, The speedometer works fine , but the odometer clicks , I will check the mentioned causes this weekend, Thanks A lot Quote Link to comment Share on other sites More sharing options...
71longtime Posted June 9, 2015 Share Posted June 9, 2015 mine did the same thing this weekend.rolled over to 46000 and just hung up.the tenths was working fine but could tell it was the 6 that the gear just didn't want to completly roll over. i had about 15 miles to get home and by the time i did the 6 rolled over.no more click. Quote Link to comment Share on other sites More sharing options...
rsorg Posted June 10, 2015 Author Share Posted June 10, 2015 Hello, My tenths are not wanting to roll along with the 5999.9 ,It is quite annoying, the clicking sound, but the sound goes away , when the secondaries open up.and the tires start laying down rubber. Quote Link to comment Share on other sites More sharing options...
stangeba Posted June 10, 2015 Share Posted June 10, 2015 I remember mine doing that about 30 years ago then it was OK. My numbers on the miles to this day don;t line up real nice ever since then. ( I think) Picture Quote Link to comment Share on other sites More sharing options...
