stickshift Posted April 23, 2008 Share Posted April 23, 2008 Here is a clip of my '72 with new hood and exhaust modifications. Check out my pistal grip four speed also. Quote Link to comment Share on other sites More sharing options...
502ci Posted April 23, 2008 Share Posted April 23, 2008 Nice...I like it... I like those wheels and hood scoop on your monte, then again I'm race oriented... How's the steering wheel on the hands after a long drive? Do I hear a noisy gear drive in there... Bill Quote Link to comment Share on other sites More sharing options...
MADMAC Posted April 23, 2008 Share Posted April 23, 2008 I can't find the video; all the other Monte vids come up, what should I look for? Quote Link to comment Share on other sites More sharing options...
Heckeng Posted April 23, 2008 Share Posted April 23, 2008 I lost a finger in one of those steering wheels once! I really like that exhaust exit and tips. Actually everything looks very nice with the car! Nice Quote Link to comment Share on other sites More sharing options...
Jared Richey Posted April 23, 2008 Share Posted April 23, 2008 Very nice. Love the sound. I bet it will go fast also. Quote Link to comment Share on other sites More sharing options...
7tonemonte Posted April 23, 2008 Share Posted April 23, 2008 Linky no worky for me??? Wonder whats up with that? Quote Link to comment Share on other sites More sharing options...
MADMAC Posted April 23, 2008 Share Posted April 23, 2008 I still couldn't get the link to work;so I jumped on Youtube and found it. Your car looks and sounds cool Quote Link to comment Share on other sites More sharing options...
Guest chico,70'chev Posted April 24, 2008 Share Posted April 24, 2008 very coooool.The interior took me back to the mid 80's.I love it!thanks for posting it. Quote Link to comment Share on other sites More sharing options...
stickshift Posted April 26, 2008 Author Share Posted April 26, 2008 My monster small block has,just to name a few, a Pete Jackson Noisy gear drive, 480 lift Comp cam, ported & polished 041 heads,1.5 roller rockers, K. Motion valve springs, Dart intake, Holley 650 double pumper, MSD 6AL, Blackjack headers, 2.5 exhaust w/X-pipe and single chamber race Flowmasters, and custom side exhaust exits, Super T10 four speed w/Centerforce dual friction clutch kit,Hurst comp shifter w/pistal grip, 3.55 Richmond geared rear end, Tangerine pearl coat paint w/gold flake and four coats of clear, and an aero hood scoop. I am not sure what my next modification will be. I thought about building a big block but gas prices are too high. I might just continue to modify my small block. Thanks for the responses guys. What do you think would be the best next move, a big block, a turbo, or a procharger??? Quote Link to comment Share on other sites More sharing options...
kc8oye Posted April 27, 2008 Share Posted April 27, 2008 stickshift.. nice i'm using a similar setup in my smallblock i have a split pattern cam tho.. 214/224° @ .050 .442/.465 lift. I have slightly ported (port matched exhaust side) stock '72 heads. i'm using SpeedPro flat-top forged pistons for 9.3:1 compression. I'm using a 700r4 with 3.55/posi (factory 10bolt) and i have far more power then I have traction thru 1st gear lol (there is no such thing as too much power) so right now I'm figureing on about 350hp.. I bet you are a bit more with that bigger cam and better heads. What intake are you running? and how do you like that Double-Pumper? I'm using a holley 600 vac. secondary. if you are concerend about gas prices, a turbo would be the way to go.. they don't hit you in the gas tank unless you bury your foot into it. Quote Link to comment Share on other sites More sharing options...
stickshift Posted April 27, 2008 Author Share Posted April 27, 2008 The intake that I am running on my Munster 72 is a Dart airgap. It is identical to Edelbrock's RPM Airgap, but it is made by Dart. My Holley 650 double pumper gives a lot of power on demand. I had to do a lot of adjusting to make it streetable, but once I got the bugs worked out, it proved to be one of the best carbs I have ever had, and I have had Holley 750 duel line, Holley 600 vacuum secondary, Quadrajet, and Edelbrock 750 performer but I really love my 650 double pumper. I have not had my car on a dyno yet but my guess would be 400 hp or more. I am curious to see what my 1/4 mile ET is. I have not ran it at the track yet but I am planning on testing it out at the local track later on this summer. I am looking for a stronger rear end with a lower gear before I run it. My rear end is the factory 10 bolt single traction modified with Richmond 3.55 gears. I will probably replace it with a 3.73 or 4.11 geared 12 bolt posi unit.I would also like to beef up the bottom half of my engine a bit more before I hit the track. My 350 is powerful with good torque, but I thought about stroking it. I think stroking my 350 could be an option. What do you guys think about the stroker engines??? Quote Link to comment Share on other sites More sharing options...
kc8oye Posted April 27, 2008 Share Posted April 27, 2008 i figure I'm making close to 350hp with my setup.. so your 400 guess is pretty close. you should be able to run mid-high 13's if you can hook up best I've done so far is 14.8 with smoking the tires thru 1st gear. Quote Link to comment Share on other sites More sharing options...
monte70car Posted April 27, 2008 Share Posted April 27, 2008 tim not to make u mad but i just ran ur motor on my dynosim and it only shows you make 300hp at 4500 rpms and then it falls after that. but u are making some good torque @ 1500 rpm's u are making 426 lbs of tq. by 2000 epms u have made the most torque at @448 lbs of torque. thats based off the infor u posted. if u advance ur timming to 1 u will down the hp down to 293hp but ur torque will go up to 450. Quote Link to comment Share on other sites More sharing options...
wallaby Posted April 27, 2008 Share Posted April 27, 2008 That'a a pretty respectable torque number. I bet it feels good in the "seat of the pants". With those numbers you can probably get good 1/4 mile times by just leaving the trans in drive. Quote Link to comment Share on other sites More sharing options...
