Ian Posted January 29, 2009 Share Posted January 29, 2009 I was looking at some pictures of Mickeys 4 speed conversion and noticed he said he had to mount the crossmember a different way.. My new exhaust is pretty close to the crossmember, do you think I could do this with my TH400 (soon to be 700R4) I have not looked at mine yet to see what way it is pointing, but I think it is the other way... Quote Link to comment Share on other sites More sharing options...
Mikstudie Posted January 29, 2009 Share Posted January 29, 2009 I think you have to do that so the mount will line up,I'am going to look at mine tonight and will let you know. I think I remember having to do that also. Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted January 30, 2009 Share Posted January 30, 2009 ??? my 4 speed car wasn't like that, PM Leo Ian, ask Tim since he's already done the swap to a 700R4 Quote Link to comment Share on other sites More sharing options...
monte70car Posted January 30, 2009 Share Posted January 30, 2009 i never turned my going from a 350th to a 400th or from a 400th to the 700r4. all i did was slide the cross member forward and back. Quote Link to comment Share on other sites More sharing options...
Ian Posted January 30, 2009 Author Share Posted January 30, 2009 I was just looking at it for the clearance issue with my pipes.. I will take a picture later and post it... Quote Link to comment Share on other sites More sharing options...
Ian Posted January 30, 2009 Author Share Posted January 30, 2009 Thanks Allan, but for $239 I'll live with mine it is not that bad. Quote Link to comment Share on other sites More sharing options...
Paul Bell Posted January 30, 2009 Share Posted January 30, 2009 There's this one from HERE Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted January 30, 2009 Share Posted January 30, 2009 I have that one Quote Link to comment Share on other sites More sharing options...
Andy's Auto Posted January 30, 2009 Share Posted January 30, 2009 I have the BMR in my Malibu. It is a very nice piece. Quote Link to comment Share on other sites More sharing options...
680HPStroker Posted January 30, 2009 Share Posted January 30, 2009 If you you are not able to spring for a aftermarket cross member. You could do what I did and just cut a stress relief in it, bend it where you need it to be, weld it back up, grind the weld smooth, paint and presto a custom cross member of your own. Soon I'll be getting one of the custom ones from P.A.T.C. Quote Link to comment Share on other sites More sharing options...
Ian Posted January 30, 2009 Author Share Posted January 30, 2009 I think the issue is that I may have it in backwards. In the picture above the mount is to the rear of the car, I looked under mine this morning, and the mount is facing the front of the car. I'll take a picture this weekend. Quote Link to comment Share on other sites More sharing options...
kc8oye Posted January 31, 2009 Share Posted January 31, 2009 Ian.. the factory crossmember fits in the correct orientation errm.. well.. now that I say that.. I have an Impala crossmember, not a monte carlo... that way mine bolts directly to the frame w/o the rubber cushions.. however because the imapala had the X-frame, the 'arches' in the crossmember are very close to the center of the car.. I just had the exhaust shop run the exhaust so that it fit my pipes sit just a 1/2" away from my driveshaft loop... Quote Link to comment Share on other sites More sharing options...
wallaby Posted January 31, 2009 Share Posted January 31, 2009 Mine is also installed with the trans mount forward. I didn't realize it could be done the other way. With the main bar under the tail housing of the trans instead of having it forward near the pan, I'd expect it would be a lot easier to service the trans or remove the engine if you had to. Quote Link to comment Share on other sites More sharing options...
Ian Posted January 31, 2009 Author Share Posted January 31, 2009 OK took some pictures, mine is facing the front right now. Would it hurt to turn it the other way for clearance? The exhaust is the MagnaFlow with a X pipe crossover. Quote Link to comment Share on other sites More sharing options...
kc8oye Posted February 1, 2009 Share Posted February 1, 2009 your clearance looks good? Quote Link to comment Share on other sites More sharing options...
Ian Posted February 1, 2009 Author Share Posted February 1, 2009 It is on the inside like yours Allan. I am thinking if I turn it around the humps will line up better with the pipes... Quote Link to comment Share on other sites More sharing options...
monte70car Posted February 2, 2009 Share Posted February 2, 2009 here is my crossmember that is 2.5" h-pipe i could only get one picture. Quote Link to comment Share on other sites More sharing options...
Ian Posted February 2, 2009 Author Share Posted February 2, 2009 Rob which way is yours facing toward the front or the rear? Quote Link to comment Share on other sites More sharing options...
monte70car Posted February 2, 2009 Share Posted February 2, 2009 i believe the mount is facing the front ian i would have to double check. i can post a picture of the elkie frame if that helps. it was set up for a 350th Quote Link to comment Share on other sites More sharing options...
kc8oye Posted February 2, 2009 Share Posted February 2, 2009 I have only 3" collectors... but because I use the impala x-member, my pipes have some really intersting bends up front Quote Link to comment Share on other sites More sharing options...
Grease Posted February 3, 2009 Share Posted February 3, 2009 Ian I dont think with the automatic it can be turned backwards like it is shown with the 4speed . The pipe would be into the oil pan I believe. Quote Link to comment Share on other sites More sharing options...
kc8oye Posted February 3, 2009 Share Posted February 3, 2009 i know it won't fit with a 700r4 like that.. at least mine wouldn't. my trans mount barely clears! Quote Link to comment Share on other sites More sharing options...
