71-72 vinyl top trim picture
32 minutes ago, Dtret said:
There is none.
I could be wrong but Bob may be looking for pictures of how the vinyl top trim on the 70 with full halo is routed and/or how the vinyl material on some 70 and all 71/72's tuck into the windshield trim.
You are correct Rob. I'm looking at how far the vinyl top trim goes to the top of the windshield
Joe said he’s going to snap a picture of his car when he goes out to the shop. If not I can pull the cover off my 71 and snap as many as you need
I'll be of no help then, because my 72 vinyl goes the full way & tucks under the W/S trim.
Yes exactly goes into the window channel.
I would like the trim to dead end into the window trim further but then it only leaves a +1/4" where it slides into the Z shaped trim.
I thought you were talking about the halo trim, and how it sits across the front.
Here's mine. Can't go much more forward than that, or it'll be sticking out/up too much.
There's a natural bend/curve in the trim that matches the curve of the roof line too. It appears to sit just right on what I have.
Thanks Joe that is the picture I am looking for. I would have thought it was a little closer to the windshield trim
It will slide fore & aft a bit, but in my case that seems to be a good spot. As mentioned above,  too far forward would maybe stick out/up too much. I'm not sure how deep it goes in the rear 'Z' piece, but both sides of the car are setup the same distance from the W/S trim.
3 minutes ago, overdrive said:
Joe, your "non halo" photo is an aftermarket top. Truly non halo.
Dan
Did you mean Dennis' photo?
I hope so. Yours is correct. The non-halo I posted was a dealer install vinyl top. At the time the question was posted I thought that was what he was looking for. As the post moved further along it got more specific.
I think he meant Dennis' photo.
Thanks Dennis
Yes, sorry. It's his photo.
Dan
