curtish57 Posted April 25 Share Posted April 25 Hi, I've posted a few times in the tech area and was advised this may be a good source to locate a yoke and possibly UV joint for my 70 monte that was a stock 350/350 car, that I am dropping a 454/400 in. I know now I need to cut the driveshaft down or buy a new one if that is more cost effective I am not experienced enough to know. So anyway I am looking for the yoke and maybe a driveshaft. Thanks! Quote Link to comment Share on other sites More sharing options...
MC1of80 Posted April 25 Share Posted April 25 What rear end are you using? The 12 bolt has a longer pinion than a 10 bolt. Also the u- joint is made by a few companies. It used to be called a "trick" joint by Lakewood. Moog also makes it, I believe it's called a "combo" joint. It has the 350 big caps and the 400 small caps. 3 Quote Link to comment Share on other sites More sharing options...
curtish57 Posted April 25 Author Share Posted April 25 It's the stock 12 bolt rear end. Would you know where I could source the correct yoke to match the u joints you mentioned? Quote Link to comment Share on other sites More sharing options...
jft69z Posted April 25 Share Posted April 25 Call Denny's driveshafts. They'll have solutions/answers to all of your concerns. Top notch workmanship too. https://www.dennysdriveshaft.com/index.html 2 Quote Link to comment Share on other sites More sharing options...
Scott S. Posted April 25 Share Posted April 25 Moog has a good selection of U joints as well. 1 Quote Link to comment Share on other sites More sharing options...
jft69z Posted April 25 Share Posted April 25 10 minutes ago, Scott S. said: Moog has a good selection of U joints as well. NAPA too 2 Quote Link to comment Share on other sites More sharing options...
willie Posted April 26 Share Posted April 26 I would agree with Joe, call a driveshaft repair. They will have the parts and know what the best course of action will be!!! 2 Quote Link to comment Share on other sites More sharing options...
70white402 Posted April 28 Share Posted April 28 I have the original driveshaft and yoke from my 70 402/400 trans. You can have it if you pay shipping. 2 Quote Link to comment Share on other sites More sharing options...
