Jamez70 Posted January 17, 2011 Share Posted January 17, 2011 Is the 4 speed shifter unique to the Monte or is it the same one as Chevelle? Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted January 17, 2011 Share Posted January 17, 2011 same Quote Link to comment Share on other sites More sharing options...
Jamez70 Posted January 17, 2011 Author Share Posted January 17, 2011 Thanks Quote Link to comment Share on other sites More sharing options...
Mikstudie Posted January 17, 2011 Share Posted January 17, 2011 I think the Chevelle is a Muncie shifter,I went with a Hurst only because the Muncie that came with the drivetrain I got out of a 69 Chevelle was worn out. Quote Link to comment Share on other sites More sharing options...
James G. Posted January 28, 2011 Share Posted January 28, 2011 I have a Hurst with my 4-speed and I love it. Quote Link to comment Share on other sites More sharing options...
Andy's Auto Posted January 28, 2011 Share Posted January 28, 2011 The Chevelle Muncie shifters are one to thier own. The thing bolts to not only the trans but also the crossmember. I bought a repop for my 68 and decided it was junk and bought a Hurst instead. But the Hurst shifter is dictated by what type of Muncie trans you have. Most are either 451 or 453 the difference being whether your shift arms bolt on or have studs. It does get confusing and I did much homework til I got it right. Quote Link to comment Share on other sites More sharing options...
Mikstudie Posted January 28, 2011 Share Posted January 28, 2011 The Chevelle Muncie shifters are one to thier own. The thing bolts to not only the trans but also the crossmember. I bought a repop for my 68 and decided it was junk and bought a Hurst instead. But the Hurst shifter is dictated by what type of Muncie trans you have. Most are either 451 or 453 the difference being whether your shift arms bolt on or have studs. It does get confusing and I did much homework til I got it right. I does get confusing,I think I called sumitt and told them to send me a short travel shifter for a rock crusher trans and they sent me what I have.(Hurst Comp.shifter) Quote Link to comment Share on other sites More sharing options...
RichG Posted January 29, 2011 Share Posted January 29, 2011 Console or no console makes a difference as well. Quote Link to comment Share on other sites More sharing options...
Vaughn Posted January 29, 2011 Share Posted January 29, 2011 Console or no console makes a difference as well. Yup Bucket and bench shifters are different. Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted January 29, 2011 Share Posted January 29, 2011 Originally Posted By: RichG Console or no console makes a difference as well. Yup Bucket and bench shifters are different. the hump on the floor is different too the only difference to the shifters is the handle, the shifter "itself" is the same Quote Link to comment Share on other sites More sharing options...
RichG Posted January 29, 2011 Share Posted January 29, 2011 Sam, I should have worded it that way. When you buy from hurst you order the shifter body and handle based on application. The shifter based on tranny and handle based on your interior. Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted January 29, 2011 Share Posted January 29, 2011 Rich, I need to research those hurst shifters too, I have a sneaky feeling I won't be happy with this wore out stock one, I do have two shifter body's to try Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted January 30, 2011 Share Posted January 30, 2011 and for your viewing entertainment, I was bored this morning and assembled my trans/shifter/crossmember, snapped a few pictures for those who haven't seen a original 4 speed set-up Quote Link to comment Share on other sites More sharing options...
Andy's Auto Posted February 1, 2011 Share Posted February 1, 2011 Sam, I wish I had those pics before ordering a repop Muncie shifter from Ausleys. I tried throwing threw thier front window and it only went as far as the lot in front of my shop. Turns out they are North of me, not South. When doing a conversion, you have to have the original crossmember. Ground Up sells the bracket, but Ausleys no only does not sell it, they don't mention it either. Went with a Hurst Comp Plus and could not be happier. Quote Link to comment Share on other sites More sharing options...
bobsmc Posted February 1, 2011 Share Posted February 1, 2011 Sam, I wish I had those pics before ordering a repop Muncie shifter from Ausleys. I tried throwing threw thier front window and it only went as far as the lot in front of my shop. Turns out they are North of me, not South. When doing a conversion, you have to have the original crossmember. Ground Up sells the bracket, but Ausleys no only does not sell it, they don't mention it either. Went with a Hurst Comp Plus and could not be happier. Andy you make me laugh!!! lmao Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted February 1, 2011 Share Posted February 1, 2011 Went with a Hurst Comp Plus and could not be happier. if I was doing a conversion that's what I would use too (was the re-pop "that" bad???) Quote Link to comment Share on other sites More sharing options...
Andy's Auto Posted February 1, 2011 Share Posted February 1, 2011 Bonesy, the shifter made by Dynacorn seems like a good piece. Took a month to get. But it suffered from TOB syndrome. Nice to look at but worthless if you are missing the small stuff, like the bracket that is welded to the crossmember. Top that with working with a 451 case Muncie, you get two sets of mounting holes to play with on the tailshaft. And with the Muncie shifter, you are only using one. If it helps, the right shifter for a console 68-72 is 3918014. It even comes with a handle and knob. Quote Link to comment Share on other sites More sharing options...
overdrive Posted February 1, 2011 Share Posted February 1, 2011 When I had my 402 4 spd. in the early '90s, there was a rebuild kit for the original Muncie shifter. Is it still available? Dan Found this. Quote Link to comment Share on other sites More sharing options...
Andy's Auto Posted February 1, 2011 Share Posted February 1, 2011 Dan, did yu catch the dates on the posts? They were 2001. The Hurst website now says $75 plus parts. Not too bad an increase in ten years. Still not bad but have no clue who does original Muncies. Quote Link to comment Share on other sites More sharing options...
overdrive Posted February 1, 2011 Share Posted February 1, 2011 Quote: Dan, did you catch the dates on the posts? They were 2001. No, I didn't look closely. I'm trying to pay attention to the weather forecast, too. 20+ in. of snow on the way for our area this afternoon and tonight w/40 mph winds. Hurst may do Muncie shifters or at the least, they may know who has the parts. It would be worth an email or call. Dan Quote Link to comment Share on other sites More sharing options...
Mom's Car Posted February 1, 2011 Share Posted February 1, 2011 maybe these guys can help........good luck http://www.skspeed.com/manual-transmission-shop.aspx Quote Link to comment Share on other sites More sharing options...
overdrive Posted February 18, 2011 Share Posted February 18, 2011 I noticed last night that OPGI has at least 2 parts that can be used in an original shifter rebuild in their latest catalog that came last week. #1 #2 The catalog shows a nylon washer with the nut, and the website has it in the text, but not in the photo. Dan Quote Link to comment Share on other sites More sharing options...
