engine # help
rollin 72 monte
  • 1 month later...
so which is better a 4 bolt main or 2 bolt main or is there any diffrence at all ans i also have 67890 rear end i was trying to get the #s on the trans but wasnt able to find it oh and my manifold is a csbx eddl. im just trying to see what im working with thanks guys
Maybe this will help.
http://www.chevellestuff.com/1972/rear_axle.htm
My engine builder said that the 2 bolt cores are better most of the time, and to use the aftermarket 4 bolt caps for high horsepower applications
Two bolt small blocks are fine for a "hot street" application. Like Ian said they make a better foundation for a high performance buildup. We have the blocks converted to four bolt blocks with the three center caps converted to 4 bolt splayed caps. By the time you get all the hipo stuff done to a stock block you can get pretty close to a aftermarket block.
thanks that web site helped out a lot so i have a 12 bolt rear end with a 2.73 gear and a 350 v8 4 bbl
