rollin 72 monte Posted February 15, 2011 Share Posted February 15, 2011 can any body tell me what kind of block this is and what it belongs to #3970010 thanks Quote Link to comment Share on other sites More sharing options...
overdrive Posted February 15, 2011 Share Posted February 15, 2011 Check here. You can put your # in a Google search for more info. I have one that's a 350 from '69 with 4 bolt mains. Some are 4, some are 2. Dan Quote Link to comment Share on other sites More sharing options...
rollin 72 monte Posted February 15, 2011 Author Share Posted February 15, 2011 thanks for the help Quote Link to comment Share on other sites More sharing options...
cny first gen 71 Posted February 15, 2011 Share Posted February 15, 2011 Hey I have a factory 4 barrel manifold for that enging it came out of a 68 327 or 350 according to the numbers on the manifold. Quote Link to comment Share on other sites More sharing options...
JOHNA01374 Posted February 18, 2011 Share Posted February 18, 2011 3970010 is the good 350 block. They have higher nickle content than other blocks and from my under standing most where 4 bolt mains. I've had a number of these and they will take a ton of abuse. Quote Link to comment Share on other sites More sharing options...
rollin 72 monte Posted March 23, 2011 Author Share Posted March 23, 2011 so which is better a 4 bolt main or 2 bolt main or is there any diffrence at all ans i also have 67890 rear end i was trying to get the #s on the trans but wasnt able to find it oh and my manifold is a csbx eddl. im just trying to see what im working with thanks guys Quote Link to comment Share on other sites More sharing options...
robs70monte Posted March 23, 2011 Share Posted March 23, 2011 4 bolt main blocks or good in a hipo engine but for a mild 350 2 bolt mains are fine they hold up fine Quote Link to comment Share on other sites More sharing options...
cudax Posted March 23, 2011 Share Posted March 23, 2011 so which is better a 4 bolt main or 2 bolt main or is there any diffrence at all ans i also have 67890 rear end i was trying to get the #s on the trans but wasnt able to find it oh and my manifold is a csbx eddl. im just trying to see what im working with thanks guys Maybe this will help. http://www.chevellestuff.com/1972/rear_axle.htm Quote Link to comment Share on other sites More sharing options...
Mike 57 Posted March 23, 2011 Share Posted March 23, 2011 The 3970010 block was use in 302s, 327s, and 350s, from 69 to 80. could be 2 or four bolt Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted March 23, 2011 Share Posted March 23, 2011 nothing wrong with a 2-bolt block Quote Link to comment Share on other sites More sharing options...
Ian Posted March 23, 2011 Share Posted March 23, 2011 My engine builder said that the 2 bolt cores are better most of the time, and to use the aftermarket 4 bolt caps for high horsepower applications Quote Link to comment Share on other sites More sharing options...
rollin 72 monte Posted March 23, 2011 Author Share Posted March 23, 2011 oh ok so 2 or 4 doesnt make a diffrence cool Quote Link to comment Share on other sites More sharing options...
Mike 57 Posted March 23, 2011 Share Posted March 23, 2011 Two bolt small blocks are fine for a "hot street" application. Like Ian said they make a better foundation for a high performance buildup. We have the blocks converted to four bolt blocks with the three center caps converted to 4 bolt splayed caps. By the time you get all the hipo stuff done to a stock block you can get pretty close to a aftermarket block. Quote Link to comment Share on other sites More sharing options...
rollin 72 monte Posted March 23, 2011 Author Share Posted March 23, 2011 Originally Posted By: rollin 72 monte so which is better a 4 bolt main or 2 bolt main or is there any diffrence at all ans i also have 67890 rear end i was trying to get the #s on the trans but wasnt able to find it oh and my manifold is a csbx eddl. im just trying to see what im working with thanks guys Maybe this will help. http://www.chevellestuff.com/1972/rear_axle.htm thanks that web site helped out a lot so i have a 12 bolt rear end with a 2.73 gear and a 350 v8 4 bbl Quote Link to comment Share on other sites More sharing options...
rollin 72 monte Posted March 23, 2011 Author Share Posted March 23, 2011 hey guys i would like to do a rear disc conversion to my monte is there one out of another car that would just bolt on or do i have to do some costumizing and would it be worth the money and trouble to do it Quote Link to comment Share on other sites More sharing options...
