Leghome Posted April 27, 2015 Share Posted April 27, 2015 I found these on E-Bay and wondered how they fasten to the dash pad http://www.ebay.com/itm/1970-1971-1972-MONTE-CARLO-DASH-PAD-MOUNTING-KIT-CORRECT-CLIPS-AND-SCREWS-/301528702819?hash=item463482df63&vxp=mtr Quote Link to comment Share on other sites More sharing options...
monte70car Posted April 27, 2015 Share Posted April 27, 2015 The clips go towards the window, under the dash pad at the front there is a opening that they pop into. The screws go towards the driver and as long as the original holes are still good they will screw in. Quote Link to comment Share on other sites More sharing options...
Leghome Posted April 28, 2015 Author Share Posted April 28, 2015 Ok I can now see that but how do the clips fasten to the dash pad before installation  in the car? Quote Link to comment Share on other sites More sharing options...
stangeba Posted April 28, 2015 Share Posted April 28, 2015 I believe mine (1971) just push in. One or more of mine no longer stay in place however. I don't have any screws going into the clips at all but these screws look like the ones that go into the pad through the glove box opening and the top of the cluster area through the wood grain. Bruce Quote Link to comment Share on other sites More sharing options...
cny first gen 71 Posted April 28, 2015 Share Posted April 28, 2015 They push in and sorta lock on to a tab on the dash pad, mine wouldnt stay on dash pad any more (replacement dash pad) so I think theres only a couple holding mine in. It hasnt fallen out yet. Quote Link to comment Share on other sites More sharing options...
overdrive Posted April 28, 2015 Share Posted April 28, 2015 I've had the clips fall away and down into the firewall area when removing the pad. I like to install the clips onto the pad and then put some good, wide tape over the base of them. Â Dan Quote Link to comment Share on other sites More sharing options...
D.E Posted April 28, 2015 Share Posted April 28, 2015 The factory one on mine had tape on clips Quote Link to comment Share on other sites More sharing options...
Leghome Posted April 28, 2015 Author Share Posted April 28, 2015 My dash pad must be an aftermarket one. There are no tabs on my pad. The so called clips on my pad are Z shaped pcs. of metal that the previous owner screwed onto the bottom of the pad and two of them fell off when I re installed when put it back in and the screws are stripped out over the dash cluster so I am trying to figure out how to go about fixing that problem. Quote Link to comment Share on other sites More sharing options...
Rob Peters Posted April 28, 2015 Share Posted April 28, 2015 Larry, Regarding repairing the screw holes so the stripped out holes can still be used. Â There are many ways of doing this. Â One of my screw holes was also stripped out and this is how I repaired it. Â Withe the dash pad laying upside down take some wooden toothpicks (they can be the round or flat toothpicks it really doesn't matter) Stick the toothpick down into the hole until it stops and break it off flush with the surface.You can keep filling and breaking each hole, leaving some room in the hole. Â Once the hole is somewhat filled with the broken off toothpicks take them back out and squeeze some glue and then refill the hole with the toothpicks and let the glue set up. Â Once it is dry you can drill a very small pilot hole into the center of the repaired hole to give the screw a guide when you try to start it. Â I use this procedure to fix many screw holes in wood and plastic and it works very well. Rob Quote Link to comment Share on other sites More sharing options...
Leghome Posted April 28, 2015 Author Share Posted April 28, 2015 TY Rob I have used that method in wood before and never even thought about it working on my dash pad. Quote Link to comment Share on other sites More sharing options...
Leghome Posted May 9, 2015 Author Share Posted May 9, 2015 The dash pad clips arrived today. It is going to be a challenge to affix them to the dash pad me thinks. I am going to pull the dash pad tomorrow and see what I can come up with. Maybe some kind of glue that is used in body shops to glue panels onto cars or some thing not yet thought of. After Market dash pad looks pretty nice but attaching can be a pain in the arse for sure. Quote Link to comment Share on other sites More sharing options...
monte70car Posted May 10, 2015 Share Posted May 10, 2015 Larry if I don't go to a car show with the 70 I can grab some pictures of the dash pad in the 72 showing the clips. Quote Link to comment Share on other sites More sharing options...
Murphy Posted May 10, 2015 Share Posted May 10, 2015 I used some clear silicone to attach my clips in place, just give it several hours to cure before installing the pad. Quote Link to comment Share on other sites More sharing options...
Leghome Posted May 10, 2015 Author Share Posted May 10, 2015 Murph did you install the clips with the front edge of said clip even with the dash pad? Quote Link to comment Share on other sites More sharing options...
Murphy Posted May 10, 2015 Share Posted May 10, 2015 My pad is original and there are slots in which the clips slid into. A couple of these slots are a bit sloppy, I mean that the clips don't stay in place. Probably due to age of the pad. The first time I removed the pad only the outside clips were in place but I found the others laying on the duct work behind the dash. That's when I silicone them in place on the pad, I've removed the pad several times since with no issues and no lost clips......... Quote Link to comment Share on other sites More sharing options...
