Traveler Posted January 23, 2024 Posted January 23, 2024 My parking brake pedal doesn’t return to the stop when released. What brings it home? Is it the rear brake cable springs or is my brake brake assembly missing a return spring….? thanks for your advice in advance 1 Quote
cny first gen 71 Posted January 23, 2024 Posted January 23, 2024 Yea the rear cable springs should bring it back, you may have adjust it up a bit tighter. Hopefully that will help. It does need to be a bit snug, but not to tight that causes drag on rear brakes. Quote
420ponies Posted January 23, 2024 Posted January 23, 2024 Do you have a service manual? It shows how to adjust the e-brake. I know someone on here will assist you on the proper method to adjust the e-brake . I'm just wondering if the cable is dry? 2 Quote
cny first gen 71 Posted January 23, 2024 Posted January 23, 2024 Good point Jim I was just assuming the cables a fairly new. Quote
420ponies Posted January 25, 2024 Posted January 25, 2024 I know this from mine, the cable coming from the pedal out the firewall, it was locked up from I believe never being used. I also think that there was old grease on it too. Had to drop it out service it when the body was off the frame. Quote
Traveler Posted January 26, 2024 Author Posted January 26, 2024 Thanks guys I have new rear brake cables now I just new to install them 3 Quote
Traveler Posted February 13, 2024 Author Posted February 13, 2024 On 1/23/2024 at 11:35 AM, 420ponies said: Do you have a service manual? It shows how to adjust the e-brake. I know someone on here will assist you on the proper method to adjust the e-brake . I'm just wondering if the cable is dry? Thanks for the reply, the cable moves, I he not tried to lube the single cable but will when I get my car out of paint lock-up, lol. I have the two rear cables and when it gets a little warmer, snowing here right now, and feel up to laying on my back to replace them, I’ll get’er done. 1 Quote
1Bad454 Posted April 14, 2024 Posted April 14, 2024 Thank you for this question! As part of my restoration I am currently sanding mine down to repaint and noticed that it doesn't have a return spring on the unit itself. I was getting ready to order a new one but wanted to check the forum first. You guys just saved me $100. 😅 3 Quote
cny first gen 71 Posted April 14, 2024 Posted April 14, 2024 9 hours ago, 1Bad454 said: Thank you for this question! As part of my restoration I am currently sanding mine down to repaint and noticed that it doesn't have a return spring on the unit itself. I was getting ready to order a new one but wanted to check the forum first. You guys just saved me $100. 😅 Well we do like to save people money sometimes but more than not we like to help spend other people's money too 😅 1 Quote
stangeba Posted April 14, 2024 Posted April 14, 2024 When I replaced the heater core on my 71 (No A/C) Monte, it turned into a real snowball. Since I had the carpet and dash all out I also blasten and painted the parking brake mechanism. Here is a picture.. before and after. I can't find the painted picture of it..... 3 Quote
1Bad454 Posted April 14, 2024 Posted April 14, 2024 Thanks for posting that picture. It looks like I'm missing the adjustable bump stop thing. Do you know what lands on the ground spot? Quote
stangeba Posted April 14, 2024 Posted April 14, 2024 If we are talking about the same thing, it's the switch that will turn on the parking brake "warning light" on the dash. I forgot to plug it back in one time and I drove the car 5 + miles with the parking brakes ON!! My Monte Carlo, is a 1971. I don't know if that matters. Not sure but the return spring (that releases the tension on the rear brakes) is part of the parking brake cables (I THINK) The {GROUND} screw I have an arrow pointing to, is the ground wire attachment point for the dashboard harness. 4 Quote
Traveler Posted August 27, 2024 Author Posted August 27, 2024 Replaced the front cable, now the parking brake works and the pedal returns home, thanks all for the advice👍 6 Quote
