ruh roh tranny trouble
mymontesa70
any tranny techs in here?....scratch that i know all of you are smile
well heres my current dilemma..
for starters i have a 350 sb with a turbo 3 trans . i also have a b&m mega shifter which will come into play later.
so, if the car is in drive and im just crusing not even putting the pedal down the car will wind up to 4 grand! before it shifts ...scary....this is the case no matter what , getting on the highway ,cruising, it does it full throttle to but that's what its always done and should do as far as im concerned
now the only way ive found to remedy this problem is if i manually bring it through the gears , if i blip the throttle and then shift i can get it to go through the gears at whatever rpm range i want when im cruising , kind of like clutch less shifting.
so to wrap things up im a total amateur when it comes to trannys and have no idea whats going on ...any advice?
as always any and all help is appreciated , i love this place
What has changed? I would also look for the vacuum line off the trans or intake. Could the kick down cable be stuck or has fallen off? Have you changed anything, moved anything? Even something a simple as a different air cleaner assembly could cause the trans vacuum line to be knocked off or pinched. Good luck!
well embarrassing as this is , and im sure there is going to be some finger waving.....i have never changed the tranny fluid or filter:( i bought when i was 18 so thats...7 years! i guess thats next on list also cant the modulator itself just go bad? i could be way off. thanks for all your help fellas ill keep you posted but expect it to be a while. im having motor issues currentley and lets just say the day has been frustrating. im sure ill post something to you gurus later asking for help.
by the way the tranny is the one thing ive really neglected on my car and now im paying for it.
never hurts to do a little preventive service work Brandon, some fresh fluid and a filter is a good idea. I would still check out any potential vacuum issues with the connection to the modulator. Yes they can fail but usually it is accompanied with a lot of smoke out of the exhaust because the trans fluid will go directly into the intake system....Dave
always check the easiest first, it's usually the problem whistle
Aint that the truth!
I pulled the tranny from my 69 Olds many years back due to it not shifting only to find out the detent cable was hung up under the hood not connected! Which reminds me, the Monte's cable is not connected to the carb also
my TH350 used to do that.. turned out the diapgrahm in the vacuum modulator had ruptured... if you have a hand-held vacuum pump, put about 15" of vacuum on the modulator (don't use much more, or you will rupture it) and make sure it will hold that vac.. and also make sure the valve inside the modulator actully moves back and forth..
don't fret.. a new adjustable modulator is only about $11 or so.
I got the adjustable one. .turned the screw all the way in. .backed it out about 2 turns and put it in... it would bark the tires no problem going into 2nd wink
i bought a generic one from my local auto parts store (it was one of those rare moments I actully bought something at autozone)
my th350 would only downshift occasionaly when I nailed it (Even with the kickdown cable connected, and adjusted)
I got used to just standing on it and letting the engine lug along in 3rd gear with my 2.73's.. one day it decided to downshift just for the heck of it.. left me climbing the freeway on ramp in a wild fishtail (naturally I wouldn't take my foot off the gas LOL)
  • 4 weeks later...
just thought id give an update i went and bought a 10 modulator from napa and now shes shifting tip top ,couldnt be happier. though i dont know how long that thing will last for 10 bucks but at least its an easy swap thanks again for the troubleshooting help.
