willie Posted September 29, 2013 Share Posted September 29, 2013 For a 72, does anyone know where the ground bracket goes on the cluster or dash. I checked the book but i cant find it. Thanks Willie Link to comment Share on other sites More sharing options...
overdrive Posted September 29, 2013 Share Posted September 29, 2013 Check Dan Link to comment Share on other sites More sharing options...
willie Posted September 29, 2013 Author Share Posted September 29, 2013 Dan Thank You for posting that! However, now i am not sure if mine had one. As everyone know my car was all apart but i do have this bracket but it has the small whole on the wire, my harness has the large washer that goes behing the headlight switch not even sure if the bracket is right for the car? What do you guys think??? Link to comment Share on other sites More sharing options...
stangeba Posted September 29, 2013 Share Posted September 29, 2013 Sorry, I couldn't say for sure since mine is a 71 NO A/C car. The video, posted prior, is very good and shows how grounding is vital. The special bracket was probably created for the assembly line to make sure all the switches were grounded and not forgotten. I think a good ground could be made with just about any wire as long as it is attached to a good ground, like the parking brake assembly. Link to comment Share on other sites More sharing options...
footballubet Posted September 29, 2013 Share Posted September 29, 2013 I'd look under my dash but it doesn't have the cluster! But if I recall correctly mine just had a wire on one of the screws on the back of the cluster. The headlight switch ground is real important but a redundant ground attached to the cluster would not hurt anything. Link to comment Share on other sites More sharing options...
Sam (Bones) Posted September 29, 2013 Share Posted September 29, 2013 I'll bet that bracket goes to the headlight switch too, put it in place and think of it as a jig-saw puzzle Link to comment Share on other sites More sharing options...
willie Posted October 2, 2013 Author Share Posted October 2, 2013 I cant figure it out yet. I agree you cant have too many grounds. I just dont think this is acorrect one even though its marked for a 72. The dash harness has 3 grounds out of it just like the vidio shows, 2 grounds and the headlight ground. But i would like to put this on if i can. I am still trying. Thanks Guys Link to comment Share on other sites More sharing options...
Toppless72 Posted October 2, 2013 Share Posted October 2, 2013 Willie, The 1972 Assembly manual does not show the bracket you have here. It only shows the large brass wire loop connected to the wire harness and attached at the headlight switch. I'm not sure where it would go if it is a 1972 part. Link to comment Share on other sites More sharing options...
7tonemonte Posted October 2, 2013 Share Posted October 2, 2013 Willie I may see it on my car. Ill try to get a pic. Not sure but it sort of looks like a bracket off of my wiper switch, then the long part goes down to a bracket that holds the bottom of the dash in place on the car. My neck hurts now! I have a pic on my phone ill send you. Link to comment Share on other sites More sharing options...
7tonemonte Posted October 2, 2013 Share Posted October 2, 2013 Well, now that I watched the vid from Dan, that's not it! I hope it was your phone I sent the pic to, if not someone out there is scratching their head Oh well, I tried Link to comment Share on other sites More sharing options...
willie Posted October 3, 2013 Author Share Posted October 3, 2013 Thanks Guys, Tony that was me, i will get to take a look again tomorrow and let you know. Thanks for folding yourself up and getting under there Tony!!! Link to comment Share on other sites More sharing options...
willie Posted August 31, 2015 Author Share Posted August 31, 2015 Holy Molly!!! I cant believe it, this post is from last Oct. The bracket turns out to be a ground bracket for a chevelle sweeping dash. Does not fit our dashes. I did put one on from a chevelle round dash with tach. I had the dash in for awhile, but had to pull it back out some, to get all the duct work in. Almost back together and I ran out of time. Thanks for all the help guys, I couldn't do this without you guys. Link to comment Share on other sites More sharing options...
