Rock Posted February 28, 2014 Share Posted February 28, 2014 I just ordered some engine parts for my Monte, I ordered a Holly double pumper 650cfm carb and dominator manifold and some nice aluminium valve covers. Is a 650 CFM to big? I have a an Elderblock 600CFM on it now and dont care for it much. Now I am not an engine guy in the least so if you guys can help me out with some of this stuff it would be appreciated. I am basically looking to beautify under the hood a little with some nicer looking parts. Not looking to win any races here. My big concern is tuning the Holly, Is it a tough carb to tune for the flat lands of MN and what kind of jets should I be using? Quote Link to comment Share on other sites More sharing options...
Daryl Posted February 28, 2014 Share Posted February 28, 2014 I think we're going to need a little more information before someone can help you out with that. Can you give us your engine basics? Size? Cam? Quote Link to comment Share on other sites More sharing options...
7tonemonte Posted February 28, 2014 Share Posted February 28, 2014 600 edelbrock here. Mostly stock 350 and never had an issue right out of the box with that carb What didn't you like about it? Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted February 28, 2014 Share Posted February 28, 2014 don't think a double pumper is a good choice unless you have a high stall and at least a 3.73 gear Quote Link to comment Share on other sites More sharing options...
cbolt Posted February 28, 2014 Share Posted February 28, 2014 Ditto on the double pumper, not necessary. No need for constant secondaries unless you are racing, but that is my opinion. I run a Carter 625 with a mild 350. (bored .060, mild cam, headers, intake) Works well and haven't made a single adjustment since I installed in in 2001 and about 60K miles. Quote Link to comment Share on other sites More sharing options...
LS5 Posted March 1, 2014 Share Posted March 1, 2014 Glen check out your other Post on the steering wheel hub… Darren. And I am running a 625 Carter on my 350 as well. Quote Link to comment Share on other sites More sharing options...
Rock Posted March 1, 2014 Author Share Posted March 1, 2014 My motor is mostly stock. Not sure on the gearing. I know it's a 12 bolt rear end. Quote Link to comment Share on other sites More sharing options...
Mike 57 Posted March 1, 2014 Share Posted March 1, 2014 A double pumper is not the way to go on a mild cruiser. What cam, gear, and converter are you running? If you are dead set on a Holley check out a vacuum secondary carb. The eddy and carter carbs are a good choice for a cruiser. Quote Link to comment Share on other sites More sharing options...
Rock Posted March 1, 2014 Author Share Posted March 1, 2014 So I should stick to an Elderblock? What size should I go with? Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted March 1, 2014 Share Posted March 1, 2014 a 600 CFM should be enough, I wouldn't go bigger than a 650 Quote Link to comment Share on other sites More sharing options...
Leghome Posted March 1, 2014 Share Posted March 1, 2014 My 2005 350/290 horse crate motor has an Elderbrock 1406 on it and it runs great. I had a Holley and could not get the car to run worth a hoot. Took the 1406 out of the box bolted it on and change the fuel line to fit the carb and it ran like a champ. Quote Link to comment Share on other sites More sharing options...
Rock Posted March 1, 2014 Author Share Posted March 1, 2014 I knew I should of talked to you guys before I placed the order. Quote Link to comment Share on other sites More sharing options...
CKZ03 Posted March 1, 2014 Share Posted March 1, 2014 Mild build 350 for me too, 600 cfm 4160 Holley Vac secondaries proper tuning required changing spring in vac secondary to slow down secondary opening rate, up 2 sizes on accelerator pump discharge nozzle and up 2 sizes on main jets (from factory defaults) Here is a couple of helpful links http://www.holley.com/applications/CarburetorSelector/CarbSelection.asp http://www.carburetion.com/Calc.asp http://www.edelbrock.com/automotive_new/misc/tech_center/install/tech_disc_cfm.shtml Quote Link to comment Share on other sites More sharing options...
MGD72Monte Posted March 1, 2014 Share Posted March 1, 2014 Holley Model 4160 - 600CFM vacuum secondaries Quote Link to comment Share on other sites More sharing options...
footballubet Posted March 1, 2014 Share Posted March 1, 2014 I'm running a 600cfm Eddy. No issues with it at all. Minor adjustments to get it tuned in and that has been it. Quote Link to comment Share on other sites More sharing options...
cbolt Posted March 1, 2014 Share Posted March 1, 2014 Where did you order from? I am sure you can send your Holley back for either a Carter (my choice) or Edelbrock (The more popular choice) with vacuum secondaries. Quote Link to comment Share on other sites More sharing options...
ClassicJJ Posted March 1, 2014 Share Posted March 1, 2014 My buddy went with a street demon carb on his camaro and he loves it! I'm running the orig Quadra jet and have never had any problems with it and honestly I do great on gas unless I'm always mashing on it but I highly Recommend finding a Q-jet, Best carb I've ever delt with and you can by reproduced ones from jegs or summit. Quote Link to comment Share on other sites More sharing options...
Leghome Posted March 2, 2014 Share Posted March 2, 2014 I got my Elderbrock 1406 at AutoZone. I have seen them on the Summit and Jegs websites. Quote Link to comment Share on other sites More sharing options...
Rock Posted March 2, 2014 Author Share Posted March 2, 2014 I ordered through Summit. I already told them I was refusing the order. They were not supposed to ship it till Monday. Quote Link to comment Share on other sites More sharing options...
monte70car Posted March 2, 2014 Share Posted March 2, 2014 Usual you can get Summit to work with you on changing your order. I know most of the parts stores in my area sells the same item that Summit or Jegs does but they have to order it. On our 355 with 390hp we have a single plane intake with a 750 Holley on it. Quote Link to comment Share on other sites More sharing options...
cbolt Posted March 2, 2014 Share Posted March 2, 2014 I ordered through Summit. I already told them I was refusing the order. They were not supposed to ship it till Monday. Are they working with you to change your order then? Quote Link to comment Share on other sites More sharing options...
Rock Posted March 3, 2014 Author Share Posted March 3, 2014 Originally Posted By: Rock I ordered through Summit. I already told them I was refusing the order. They were not supposed to ship it till Monday. Are they working with you to change your order then? Been exchanging emails with them. Only thing I really need to change is the carb and fuel rail. The rest I can use. I think.....can I use a Holly manifold with an edelbrock carb? Pretty sure it should work but I better ask the experts first. Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted March 3, 2014 Share Posted March 3, 2014 yes, the Edelbrock carb is a square bore carb like the Holley Quote Link to comment Share on other sites More sharing options...
cbolt Posted March 3, 2014 Share Posted March 3, 2014 Actually if they are similar to Jegs, they should have experts in their customer service department who can assist you in matching the correct parts to the application. I don't use Summit often so I cant say for sure what kind of expertise they have on hand. Of course the FGMCC members are experts as well as I am sure you can find many different set-ups on our Montes which all work great and the owners are happy with. Quote Link to comment Share on other sites More sharing options...
Rock Posted March 4, 2014 Author Share Posted March 4, 2014 Looking at this carb....Yeah or nay? Holly Street Avenger. http://www.summitracing.com/parts/hly-0-86670rd/overview/ Quote Link to comment Share on other sites More sharing options...
