QuadGTI Posted July 16, 2014 Share Posted July 16, 2014 Took my Monte to a shop to check out the AC Done a pressure test and it held good for 30 min Pumped R134 into system After running car the air was mild colder Low side showed 60 It just would not blow ice cold at all Are we missing something? Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted July 17, 2014 Share Posted July 17, 2014 the low side should pull down into the 30-40's was your car converted to used 134? if it was sounds like there's too much 134 in it or the POA VALVE IS BAD Quote Link to comment Share on other sites More sharing options...
Murphy Posted July 17, 2014 Share Posted July 17, 2014 I converted to R134 a few weeks back but didn't get very cool air. WE had proper pressures (no leaks) but didn't get much cool air, revacuated the system, replaced the expansion valve ($18), recharged and she now cools GREAT, even in Phoenix! Quote Link to comment Share on other sites More sharing options...
footballubet Posted July 17, 2014 Share Posted July 17, 2014 The POA valve needs revamped for 134@. Quote Link to comment Share on other sites More sharing options...
QuadGTI Posted July 17, 2014 Author Share Posted July 17, 2014 Yes converted to 134A Murphy where did you get the expansion valve from? Will give it another try this weekend. Quote Link to comment Share on other sites More sharing options...
Murphy Posted July 17, 2014 Share Posted July 17, 2014 NAPA, Looks like an exact replacement...... http://www.napaonline.com/Catalog/Catalo...7300_0140429775 We vacuumed down the system for about an hour, replaced the valve, pulled a vacuum again and let it sit for 20min to see if we would loose vacuum (leaking) it did not, then recharged to 80% of R12 volume and she works great! The old valve was stuck open, IMO. Quote Link to comment Share on other sites More sharing options...
QuadGTI Posted July 17, 2014 Author Share Posted July 17, 2014 That may be the problem, thx How much does our system take, volume Quote Link to comment Share on other sites More sharing options...
CKZ03 Posted July 17, 2014 Share Posted July 17, 2014 I put in 2.8 lbs of 134a and my system works great! Quote Link to comment Share on other sites More sharing options...
Murphy Posted July 18, 2014 Share Posted July 18, 2014 I put in 2.8 lbs of 134a and my system works great! DITTO! Quote Link to comment Share on other sites More sharing options...
Jared Richey Posted July 19, 2014 Share Posted July 19, 2014 3 12oz cans of 134 is what is in my car now. Blowed ice cold for a week, then nothing. Took it back and I had a leaky valve stem on the line going to the Expansion valve, sucked it back out, leak test, vacuum, etc. Put in dye, replaced valve, charged, Boom Ice Again. Fingers crossed for no more leaks! I have new Reciever/Drier, Expansion Valve, POA Valve Update Kit, original condenser and Evaporator core and all hoses, original style long compressor, don't know if was new or a rebuilt one, it was on a truck that I got my 454 engine out of. Quote Link to comment Share on other sites More sharing options...
Murphy Posted July 19, 2014 Share Posted July 19, 2014 Finally found that black insulator tar-like stuff. I had to buy a 25' roll but this stuff is excellent. Tar-like tape, 1/8" thick and about 2.5" wide, cut it into strips and with wet fingers you can mold it beautifully. If anyone needs to replace their insulation on the expansion valve bulb, this is the stuff! Quote Link to comment Share on other sites More sharing options...
footballubet Posted July 19, 2014 Share Posted July 19, 2014 Finally found that black insulator tar-like stuff. I had to buy a 25' roll but this stuff is excellent. Tar-like tape, 1/8" thick and about 2.5" wide, cut it into strips and with wet fingers you can mold it beautifully. If anyone needs to replace their insulation on the expansion valve bulb, this is the stuff! Where did you get that from? Inquiring minds want to know. Quote Link to comment Share on other sites More sharing options...
Murphy Posted July 19, 2014 Share Posted July 19, 2014 NAPA, when I got the expansion valve there, I asked about this tar-tape and the guy couldn't find anything in the inventory, then Mel (the owner) over heard what I was looking for and he said he had a box of dumdum tape that he ordered for a guy a few yrs ago and was never picked up. Mel went to the back & after a few minutes he found it but said I had to buy the roll (25') It was waxpaper covering the tar. On the NAPA receipt, it shows "misc tape" This is a very old NAPA location so who knows what other stuff is stashed in there warehouse........ I used maybe 1.5' to fix up the 2 tubes on the evaporator box but I can see other places to use it (under the dash possibly) If you want a few feet, no problem! Quote Link to comment Share on other sites More sharing options...
footballubet Posted July 19, 2014 Share Posted July 19, 2014 I don't need any....yet! Just was thinking if anybody here needed to buy some, where they could purchase it from. Thanks! Quote Link to comment Share on other sites More sharing options...
7tonemonte Posted July 19, 2014 Share Posted July 19, 2014 If he called it dum dum I'd say it's just windshield butyl tape, sounds like it from your description too. If so just ask for it at most parts stores, I have some in my refrigerator keeps it fresh! Also,used it around all trim screws and bolts for tail lights etc..... Quote Link to comment Share on other sites More sharing options...
Mo's70MCs Posted July 19, 2014 Share Posted July 19, 2014 I remember using similar stuff back in the day made by 3M, although in the electrical trade there was a similar product made by a company "permabond" where we purchased our duct seal. The Dum Dum..name priceless, right up there with 200mph tape we used in the military. thanks for sharing Murph Quote Link to comment Share on other sites More sharing options...
footballubet Posted July 19, 2014 Share Posted July 19, 2014 That doesn't look like the butyl dum dum I'm familiar with. That almost looks just like the stuff from factory. Quote Link to comment Share on other sites More sharing options...
Murphy Posted July 19, 2014 Share Posted July 19, 2014 Thought I better show a pic......... It's very tacky and you can shape it like clay. Quote Link to comment Share on other sites More sharing options...
black07ss Posted July 19, 2014 Share Posted July 19, 2014 Seems like it is called Prestite Tape. Auto Zone has it on line for $14.00 linky Quote Link to comment Share on other sites More sharing options...
black07ss Posted July 23, 2014 Share Posted July 23, 2014 I ordered a roll, it should be here Thursday 7-24-2014. I will let everyone know if the mystery has been solved Quote Link to comment Share on other sites More sharing options...
footballubet Posted August 4, 2014 Share Posted August 4, 2014 I ordered a roll, it should be here Thursday 7-24-2014. I will let everyone know if the mystery has been solved Well..... ?? Quote Link to comment Share on other sites More sharing options...
Arvizu9618 Posted August 14, 2014 Share Posted August 14, 2014 Hey Murph, I might hit you up for some of that dum dum tape when I'm ready to put my A/C back together. Did you ever have your POA Valve recalibrated or reconditioned for R-134? Thanks Art Quote Link to comment Share on other sites More sharing options...
