snomobeelr Posted April 24, 2016 Share Posted April 24, 2016 Was trying to bleed the brakes. Pedal is staying soft. I bench bled the Master . Brake fluid is coming out bet the pedal does not harden up. Is there also something I need to do with the Proportioning valve? Is it possible the Master is bad? Quote Link to comment Share on other sites More sharing options...
monte70car Posted April 24, 2016 Share Posted April 24, 2016 You might have to reset the Proportioning valve. Quote Link to comment Share on other sites More sharing options...
MCfan Posted April 24, 2016 Share Posted April 24, 2016 There's a push button valve on the back side of the proportioning valve that must be held in while bleeding the front brakes. I used two door leveling shims between the vacuum booster and the valve to hold the button in. Don't forget to remove it before you go for a drive. I always bleed the rear brakes first, followed by the front. Sometimes it goes smoothly, sometimes it's a bear - not sure why. Quote Link to comment Share on other sites More sharing options...
snomobeelr Posted April 24, 2016 Author Share Posted April 24, 2016 This will be interesting , My Proportioning valve is located down on the frame. Its from inline-tube. So I have to keep the black button Depressed while bleeding the Fronts? When bench bleeding the Master the air is out but the front Bowl - port of the Master seems to blow Fluid up when Bench bleeding. Is this Normal? Link below to a video of it. Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted April 24, 2016 Share Posted April 24, 2016 yes, as Dennis suggested, do the rears first, and if the rear brakes are not adjusted, that will give you a low pedal too first I suggest to adjust the rear brakes if you do not get fluid flow from the front bleeders, push the valve in Quote Link to comment Share on other sites More sharing options...
lastss Posted April 24, 2016 Share Posted April 24, 2016 Gm factory manuall state bleed LF,RF,LR,RR always shortest distance from Master Cly to furriest. Are your rear shoes adjusted properly?.When yo push down on petal does it stop at some point & stay hard? You can adjust petal height if necessary under dash. Quote Link to comment Share on other sites More sharing options...
lastss Posted April 24, 2016 Share Posted April 24, 2016 If there's air in the system doing rears first only makes it harder to remove & making air travel that much farther to get out. & could results in some not getting out. Quote Link to comment Share on other sites More sharing options...
snomobeelr Posted April 24, 2016 Author Share Posted April 24, 2016 Thanks much guys, I 1 Quote Link to comment Share on other sites More sharing options...
snomobeelr Posted April 24, 2016 Author Share Posted April 24, 2016 Oops combination keys ........... I had bled the brakes. I Started on the rear Passenger side. I do get fluid out of all for wheels. I bleed them 3 times. Same condition. Pedal does not Harden up. All brake component lines metal and rubber are relatively new.. The rear brakes are adjusted. Quote Link to comment Share on other sites More sharing options...
snomobeelr Posted April 24, 2016 Author Share Posted April 24, 2016 One thing, I did add a hydro-boost unit but I don't think that shouldn't effect this as that is a brake asset unit and I am just bleeding the brake system. I did adjust pedal out. Quote Link to comment Share on other sites More sharing options...
snomobeelr Posted April 24, 2016 Author Share Posted April 24, 2016 Since the master is on the bench I was bleeding it again. My vise is by the window and the sun was coming through. I could see tiny miniscule bubbles in the hose to the front bowl. I bled the master until they cleared out. I saw online about the level of the car and the Master cylinder that air can get trapped. I have been changing the level/pitch of the master cylinder in the vise. The bubbles continue in the front bowl an go away. I reposition the master and bled it again and they return. I even changed the bleeding fitting that goes into the master and the hose. I also put grease around the fitting to seal it up.. When I reposition the master I get the same tiny bubbles coming from the line into the hose. Quote Link to comment Share on other sites More sharing options...
snomobeelr Posted April 29, 2016 Author Share Posted April 29, 2016 So I opted and got a new master. Its been bench bled. When I was bleeding the brakes with the old Master cylinder I kept the lid on. Should the lid be on or off the master when bleeding the brakes? Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted April 29, 2016 Share Posted April 29, 2016 I leave it on when I bleed them Quote Link to comment Share on other sites More sharing options...
snomobeelr Posted May 1, 2016 Author Share Posted May 1, 2016 Thanks guys. It was the Master cylinder. Strange I thought when they went they leaked. My son and wife are thrilled they don't have to assist me bleeding the brakes any longer. I decided to go with the Wilwood Black master even though expensive as it looks a lot nicer. Hers some pictures with the Hydroboost and New master installed.. Quote Link to comment Share on other sites More sharing options...
7tonemonte Posted May 1, 2016 Share Posted May 1, 2016 Nice looking engine bay! The master cylinder looks great also Quote Link to comment Share on other sites More sharing options...
stangeba Posted May 1, 2016 Share Posted May 1, 2016 Looks great! Quote Link to comment Share on other sites More sharing options...
bigscaht Posted May 6, 2016 Share Posted May 6, 2016 looks great.....glad you got it figured out....your gonna love your brakes.... Quote Link to comment Share on other sites More sharing options...
