Canuck 799 Posted August 26, 2020 Share Posted August 26, 2020 I still have the original heat riser On my 70 Monte. It makes quite the rattling noise when cold but is quiet once the engine warms up and it opens all the way. Is there a way to quiet it down? Back in 1997 I wrapped a piece of coat hanger wire around it to jam it open. It stayed that way until I just had it blasted and ceramic coated. I’m now reminded why I jammed it open, haha. RODS70BB 1 Quote Link to post Share on other sites
Dtret 270 Posted August 26, 2020 Share Posted August 26, 2020 If you want to keep the original on the car you can take it off pull it apart and weld a bead on the shaft then grind it down. There is probably a grove on the shaft from opening and closing and when it warms up the metal expands to shut up the noise Quote Link to post Share on other sites
cny first gen 71 431 Posted August 26, 2020 Share Posted August 26, 2020 Or you can replace it. Quote Link to post Share on other sites
MC1of80 516 Posted August 26, 2020 Share Posted August 26, 2020 You can also replace it with an open spacer or the original type spacer. I used the open spacer on Barn Find. I got mine from Ground Up. They have them for small and big blocks. RODS70BB 1 Quote Link to post Share on other sites
Rob Peters 1,195 Posted August 27, 2020 Share Posted August 27, 2020 JEGS: https://www.jegs.com/i/OER+Equipment+Reproduction/691/3887023/10002/-1?gclid=CjwKCAjwkJj6BRA-EiwA0ZVPVrjJeBfDJyKG_tAl_y8k-DfQ_YfQT2SZJLBPhjjXHU9qffKxH0ayvBoCEQ0QAvD_BwE SUMMIT: https://www.summitracing.com/parts/oer-3887023?seid=srese1&gclid=CjwKCAjwkJj6BRA-EiwA0ZVPVkaW0KmHyE6H0dTAcfwdKTe6-n4ZHyDWVpZQ6M8EgtBbJJRR1HYUgxoC2CEQAvD_BwE rob Quote Link to post Share on other sites
RODS70BB 21 Posted August 28, 2020 Share Posted August 28, 2020 Well now, since this was brought up, I have a question. I’m going back to factory exhaust manifolds and bought the spacer. I can’t seem to find what side it goes on. I seem to remember it being on the driver side. It would make sense as there is more room there on the big block cars. So which side? Thanks, Rodney Quote Link to post Share on other sites
Dtret 270 Posted August 28, 2020 Share Posted August 28, 2020 Pass Quote Link to post Share on other sites
stangeba 321 Posted August 28, 2020 Share Posted August 28, 2020 Rodney, On my 71 350 4BBL it was on the passenger side. I added a Walker dual exhaust and left it out 30+ years ago and now have lost it. Good luck, Bruce Quote Link to post Share on other sites
MC1of80 516 Posted August 28, 2020 Share Posted August 28, 2020 Rodney, it goes on the passenger side on both big and small blocks. Quote Link to post Share on other sites
Canuck 799 Posted August 29, 2020 Author Share Posted August 29, 2020 As others have said it is on the pass side. Thanks for the suggestions. The new risers and spacers are pricey so was looking at alternatives. I might simply jam it open again and ask the question in another 23 years, LOL. Quote Link to post Share on other sites
RODS70BB 21 Posted August 30, 2020 Share Posted August 30, 2020 Thanks guys! Quote Link to post Share on other sites
