Lou Posted April 10, 2022 Share Posted April 10, 2022 Upon cleaning and bench bleeding I found the front reservoir is non-operational. Upon disassembly and removal of lock spring I found that the piston assembly will not come out. There's a small bolt in the bottom of the reservoir that I removed but piston assembly still won't come out. It doesn't feel like there's a burr at the lock spring groove. What am I missing? Quote Link to comment Share on other sites More sharing options...
Lou Posted April 10, 2022 Author Share Posted April 10, 2022 Front spring is suspect. Not seeing any movement. Quote Link to comment Share on other sites More sharing options...
cny first gen 71 Posted April 10, 2022 Share Posted April 10, 2022 I don't even try to rebuild them anymore I just get a new one, there not that much and it's brand new. Just make sure it's correct looking for your car. 2 Quote Link to comment Share on other sites More sharing options...
Dtret Posted April 10, 2022 Share Posted April 10, 2022 I agree new one. But if they want the core back just pay the price and keep the original one. It’s always good to have Quote Link to comment Share on other sites More sharing options...
Lou Posted April 10, 2022 Author Share Posted April 10, 2022 Any ideas what could be hanging up? Quote Link to comment Share on other sites More sharing options...
Lou Posted April 10, 2022 Author Share Posted April 10, 2022 Got it. Compressed assembly until it stopped and gave it a wack with my persuasion tool. Seals are bad. Quote Link to comment Share on other sites More sharing options...
Scott S. Posted April 10, 2022 Share Posted April 10, 2022 Nobody likes it when a rubber fails...... 1 3 Quote Link to comment Share on other sites More sharing options...
MC1of80 Posted April 10, 2022 Share Posted April 10, 2022 I also just buy new. Amazon, 29.95 ac/Delco brand new. Quote Link to comment Share on other sites More sharing options...
Lou Posted April 11, 2022 Author Share Posted April 11, 2022 I'll work with what I have. First time I've ever gotten into a master cylinder. Quote Link to comment Share on other sites More sharing options...
cny first gen 71 Posted April 11, 2022 Share Posted April 11, 2022 8 minutes ago, Lou said: I'll work with what I have. First time I've ever gotten into a master cylinder. I can understand that, there really isn't to much to them. Just make sure the cylinder wall is in good shape. Good luck with it. Quote Link to comment Share on other sites More sharing options...
Lou Posted April 11, 2022 Author Share Posted April 11, 2022 Ran my gun cleaning kit through it with scothbrite pad and wd40. I'm seeing pitting on the bore. I think its beyond honing. Almost looks like a bad casting, like sand pits. Â Quote Link to comment Share on other sites More sharing options...
cny first gen 71 Posted April 11, 2022 Share Posted April 11, 2022 May be time for a new one but if you do end up using it make sure you clean the wd40 out of it real good. Oil and brake fluid is not compatible. 1 Quote Link to comment Share on other sites More sharing options...
Lou Posted April 11, 2022 Author Share Posted April 11, 2022 Denatured alcohol or acetone, right? 1 Quote Link to comment Share on other sites More sharing options...
cny first gen 71 Posted April 11, 2022 Share Posted April 11, 2022 Yup that will work. I do also remember at some point in time at some seminar somewhere the instructor said NEVER hone out a master cylinder or wheel cylinder. I really don't remember the reason why. Quote Link to comment Share on other sites More sharing options...
jft69z Posted April 11, 2022 Share Posted April 11, 2022 Sort of defeats the purpose of a brake hone then, lol. That being said, new is the way to go unless you're looking for 100% originality. In that case, a stainless sleeve would probably be my choice. Quote Link to comment Share on other sites More sharing options...
Lou Posted April 11, 2022 Author Share Posted April 11, 2022 Original engine is long gone. Originality is no goal for me with this one. That said, I bought the rebuild kit on Amazon for $23. Would have loved to go down to the local O'Reilly's to purchase but the same kit from Dorman there was $50. I'm sure at a later date I'll be purchasing a master and booster assembly but not at this time. Thanks everybody for helping on this issue. Quote Link to comment Share on other sites More sharing options...
Lou Posted April 11, 2022 Author Share Posted April 11, 2022 FYI: Useful tip. At least when a man has a 'junk drawer' and needs three hands, he can put 'junk' to good use: 1 Quote Link to comment Share on other sites More sharing options...
jft69z Posted April 11, 2022 Share Posted April 11, 2022 3 hours ago, Lou said: I'm sure at a later date I'll be purchasing a master and booster assembly but not at this time. Thanks everybody for helping on this issue. I have a brand new booster & a new master with about 10 miles on it if you decide that's the way you want to go. Booster is a 'Right Stuff' brand with the 'Delco Morraine' stamp & the master is from NAPA. I crossed over to 4 wheel discs shortly after building my 72 & this stuff wasn't needed after that. Quote Link to comment Share on other sites More sharing options...
Dtret Posted April 12, 2022 Share Posted April 12, 2022 4 hours ago, Lou said: Original engine is long gone. Originality is no goal for me with this one. That said, I bought the rebuild kit on Amazon for $23. Would have loved to go down to the local O'Reilly's to purchase but the same kit from Dorman there was $50. I'm sure at a later date I'll be purchasing a master and booster assembly but not at this time. Thanks everybody for helping on this issue. Just out of curiosity. 23 for a rebuild kit or 40 for a new one. If you don’t care about going for original , then why the hassle?  I get the learning experience I’m ok with that. I’ve spent alot more for learning purposes and a lot of times trashed what I was doing. But brakes are kind of important, that’s got to be right. Like I said just curious. Quote Link to comment Share on other sites More sharing options...
Lou Posted April 12, 2022 Author Share Posted April 12, 2022 I don't know. It's what I have and I'm not a quitter. Anybody can buy new and bolt it on. My wife thinks I'm nuts also because I rebuilt our over the range microwave that's 25+ years old. Works like new and built better than anything out there today. I enjoy it. Just weird I guess. Quote Link to comment Share on other sites More sharing options...
Dtret Posted April 12, 2022 Share Posted April 12, 2022 Just now, Lou said: I don't know. It's what I have and I'm not a quitter. Anybody can buy new and bolt it on. My wife thinks I'm nuts also because I rebuilt our over the range microwave that's 25+ years old. Works like new and built better than anything out there today. I enjoy it. Just weird I guess. Nope not weird. I get it. Like I said I have done it too. For some reason it always ends up costing me more in the end. Lol. Quote Link to comment Share on other sites More sharing options...
MC1of80 Posted April 12, 2022 Share Posted April 12, 2022 Amazon, 28.79 NEW ac/Delco master cylinder. 1 Quote Link to comment Share on other sites More sharing options...
Michael Boyte Posted April 12, 2022 Share Posted April 12, 2022 58 minutes ago, MC1of80 said: Amazon, 28.79 NEW ac/Delco master cylinder. Now that's cheap enough ! 1 Quote Link to comment Share on other sites More sharing options...
Lou Posted April 19, 2022 Author Share Posted April 19, 2022 Done. Refurbished it, bled it, tried to pressurize it, let it sit for a day or two in the vise. No leaking yet. Time (and pressure when I bleed the system) will tell...... 1 Quote Link to comment Share on other sites More sharing options...
