GriffsMonte Posted January 11, 2015 Share Posted January 11, 2015 So i have changed everything on this engine including plugs,plug wires,cap, rotor, coil and a brand new platinum duralast. The darn thing is still popping through the carb with vapors but only when you slam on the gas . so im asking for any suggestions on what it might be ? Or what engine should i replace it with and get the best bang for my buck. P.s. Put a vac gauge on it and it just vibrates from 19 to 21 back and forth. Quote Link to comment Share on other sites More sharing options...
72jrfan88 Posted January 11, 2015 Share Posted January 11, 2015 I had a similar issue last year and mine was a combination of my timing/dwell was off and my carb was set running way to rich. I replaced plugs and distributor after I reset the timing and has been great ever since Quote Link to comment Share on other sites More sharing options...
GriffsMonte Posted January 11, 2015 Author Share Posted January 11, 2015 Yea, i did all that today because i saw on the web where it said a vibrating needle on a vacuum gauge means its an ignition problem. i dint do the dwell because i don't know how. i do have the timing set at 8* right now and she starts idles and drives fine at low rpm. Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted January 11, 2015 Share Posted January 11, 2015 carburator Quote Link to comment Share on other sites More sharing options...
overdrive Posted January 11, 2015 Share Posted January 11, 2015 Are you using points in your distributor? The dwell angle adjustment is for points. Dan Quote Link to comment Share on other sites More sharing options...
GriffsMonte Posted January 11, 2015 Author Share Posted January 11, 2015 sam, i have put 2 600 eddy's on both doing the same thing. maybe ill get a cheap q-jet and see if that'll change anything Quote Link to comment Share on other sites More sharing options...
GriffsMonte Posted January 11, 2015 Author Share Posted January 11, 2015 Dan, i dont know too much about dizzys, i just know its the hei with vacuum advance and the internal coil on top. Quote Link to comment Share on other sites More sharing options...
72jrfan88 Posted January 11, 2015 Share Posted January 11, 2015 I should also of clarified. With mine I have factory points distributor and original carter q jet carb. Sounds like you may not have the points. Could be a carb issue like Sam stated. Did you try a good carb cleaning or running some seafoam down the carb? That also smoothed things out for me in the past. Would hate to see you look to replace the whole engine if something simple can fix it. Good luck to you Quote Link to comment Share on other sites More sharing options...
GriffsMonte Posted January 11, 2015 Author Share Posted January 11, 2015 I never thought of oing any carb cleaning since the carb was brand new when i put it on. Quote Link to comment Share on other sites More sharing options...
monte70car Posted January 11, 2015 Share Posted January 11, 2015 How did your tighten the carb down? I know Holley's you tighten the front bolt then go to the rear bolt across from it then to the front bolt on that side and then the other rear bolt so you don't wrap the mounting plate. Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted January 11, 2015 Share Posted January 11, 2015 Is it multiple pops or just one pop? Quote Link to comment Share on other sites More sharing options...
GriffsMonte Posted January 11, 2015 Author Share Posted January 11, 2015 Rob i tightened everything down in an x formation, front right then left back etc. Sam, when you get down on it you can hear the pop with every rotation and its constant. I think vapors only come out on the first pop but it might be with every rotation also Quote Link to comment Share on other sites More sharing options...
monte70car Posted January 11, 2015 Share Posted January 11, 2015 has the valve train been messed with? new cam, new rocker arms? Quote Link to comment Share on other sites More sharing options...
footballubet Posted January 11, 2015 Share Posted January 11, 2015 What did the old plugs look like, color, build up etc? If it's with every rotation sounds like a lifter or cam lobe starting to wear down. Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted January 11, 2015 Share Posted January 11, 2015 What did the old plugs look like, color, build up etc? If it's with every rotation sounds like a lifter or cam lobe starting to wear down. that's where I was going with the multiple pops, if it's popping constantly, you better start looking at the cam Quote Link to comment Share on other sites More sharing options...
Boots Posted January 11, 2015 Share Posted January 11, 2015 I may be off base ..but what about a small video clip of the problem..your engine interpretation and written word may conflict. (no offense)....seeing and hearing the problem may be just the ticket for guys like Sam et al,.. that are knowledgeable about strange happenings in motors..????????? Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted January 11, 2015 Share Posted January 11, 2015 a single "pop" when to gas it is usually a lean condition constant multiple pops while accelerating is usually a cam lobe, valve or valve train issue Quote Link to comment Share on other sites More sharing options...
GriffsMonte Posted January 11, 2015 Author Share Posted January 11, 2015 I can put a video up tonight hopefully Quote Link to comment Share on other sites More sharing options...
GriffsMonte Posted January 11, 2015 Author Share Posted January 11, 2015 Hey guys here the video https://www.youtube.com/watch?v=RP-X84bPqPs&feature=youtu.be Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted January 12, 2015 Share Posted January 12, 2015 you definitely have a engine issue I would start by adjusting the valves any recent engine work? pulling the plugs may give you an indication on which cylinder(s) to look at Quote Link to comment Share on other sites More sharing options...
GriffsMonte Posted January 12, 2015 Author Share Posted January 12, 2015 only thing i had done was a new intake put on. How would i adjust the valves ? and when i pull the plugs what am i looking for ? Quote Link to comment Share on other sites More sharing options...
Mike 57 Posted January 12, 2015 Share Posted January 12, 2015 Sounds like valve train to me. I am hearing popping all the time. The valves may be adjusted too tight or an exhaust lobe is going. Quote Link to comment Share on other sites More sharing options...
GriffsMonte Posted January 12, 2015 Author Share Posted January 12, 2015 is exhaust lobe the same as cam lobe mike ? Quote Link to comment Share on other sites More sharing options...
Malyc Posted January 12, 2015 Share Posted January 12, 2015 The exhaust lobe is the lobe on the camshaft that opens the exhaust valve. Quote Link to comment Share on other sites More sharing options...
GriffsMonte Posted January 12, 2015 Author Share Posted January 12, 2015 thanks malyc Quote Link to comment Share on other sites More sharing options...
