Monte7071 Posted March 9, 2012 Share Posted March 9, 2012 Just grasping at straws but what about one of the drums. If he rotated the tires wouldnt th vibration move also. Quote Link to comment Share on other sites More sharing options...
Mo's70MCs Posted March 9, 2012 Share Posted March 9, 2012 more of a reason to suspect the wheels (rims) specially with a dual hub pattern. A flawed wheel could have made it through quality control, or bent at that? Â Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted March 9, 2012 Share Posted March 9, 2012 Just grasping at straws but what about one of the drums. If he rotated the tires wouldnt th vibration move also. Â not if it not the tires or wheels Quote Link to comment Share on other sites More sharing options...
Monte7071 Posted March 10, 2012 Share Posted March 10, 2012 Thats what Im saying if he rotated the tires and the vibration is the same then wouldnt that remove the tires and wheels from being suspect. If its in the rear and it was there before the rearend rebuild then it shouldnt be any of the parts he replaced during the rebuild. Im not saying I am right or wrong just trying to help. Jim to fully eliminate the wheels and tires can you swap with anybody. How long have you been dealing with this what all has been done to try and resolve the issue. Quote Link to comment Share on other sites More sharing options...
Mike 57 Posted March 10, 2012 Share Posted March 10, 2012 Also check for excessive play at the transmission output shaft. If the bushing is worn it will cause a vibration at different speeds. Quote Link to comment Share on other sites More sharing options...
rah72(Rick) Posted March 10, 2012 Share Posted March 10, 2012 I have the Wheel Vintiques on my daily driver...I have not had any issues with them, This is my second set of these I had( had a set on my 91 Full size pick up) on that truck they eneded up replacing a wheel for me IT WAS OUT OF ROUND. When I had the tires put on had a vibration that they could not fix. I contacted vintiques the first set I had I bought directly through them so I only dealt with them. They said it is unusual but it can happen. They actually sent me a new wheel before I took the other one off had the tire installed no vibration. Other than that one issue their wheels have been good to me Quote Link to comment Share on other sites More sharing options...
Canuck Posted March 11, 2012 Share Posted March 11, 2012 My 72 has a vibration at 38 to 40 MPH. I have not figured mine out either but I know it's not the wheels. I'm guessing it's the tranny in my car. Quote Link to comment Share on other sites More sharing options...
Big Jim Posted March 12, 2012 Author Share Posted March 12, 2012 One of my fellow cruisers said it could be the torque converter causing the problem. Quote Link to comment Share on other sites More sharing options...
LS5 Posted March 13, 2012 Share Posted March 13, 2012 I would say Jim you have a lot of suggestions, and as always start with the cheapest and go from there. My guess is the cheapest would be that U joint by the diff.. Darren. Quote Link to comment Share on other sites More sharing options...
Ian Posted March 13, 2012 Share Posted March 13, 2012 I had the exact same problem with my Wheel Vintiques Ralleys till I had them balanced on the car. They are not a hub centric wheel and unless you balance them on a machine that uses the lugs as the centering point they will not balance right. I fought the same issue you are a few years ago. After I had them done on the car 99% of the vibration was gone. They are going bye bye as soon as I get the new wheels out of the box and on the car Quote Link to comment Share on other sites More sharing options...
wallaby Posted March 14, 2012 Share Posted March 14, 2012 I wonder if a shop that does smog tests would let you put the car on their rollers and run her up to speed? From the outside it might be real obvious where the problem is. Quote Link to comment Share on other sites More sharing options...
Big Jim Posted March 15, 2012 Author Share Posted March 15, 2012 If the driveshaft balance does not take care of it I will search for someone with a roll around balancer that does it on the car. Quote Link to comment Share on other sites More sharing options...
Big Jim Posted March 15, 2012 Author Share Posted March 15, 2012 Where did you get your wheels? Quote Link to comment Share on other sites More sharing options...
Ian Posted March 16, 2012 Share Posted March 16, 2012 I got both the Ralleys and the new ones from Summit.. Quote Link to comment Share on other sites More sharing options...
Big Jim Posted March 17, 2012 Author Share Posted March 17, 2012 Well the Driveshaft has been balanced and my mechanic said he drove it between 60-80 and no vibration hallelujeah. I haven't had a chance to drive it on the highway yet but I trust him. I will soon weather permitting. I can't believe this part of the journey might be over. Â Quote Link to comment Share on other sites More sharing options...
Canuck Posted March 17, 2012 Share Posted March 17, 2012 Good to hear Jim. Quote Link to comment Share on other sites More sharing options...
MGD72Monte Posted March 17, 2012 Share Posted March 17, 2012 Hopefully that was it, look forward to your personnal confirmation. Quote Link to comment Share on other sites More sharing options...
Mo's70MCs Posted March 17, 2012 Share Posted March 17, 2012 Hopefully that was it, look forward to your personnal confirmation. Â Quote Link to comment Share on other sites More sharing options...
Big Jim Posted March 18, 2012 Author Share Posted March 18, 2012 Thanks for all the help and suggestions. I'll let you know. Quote Link to comment Share on other sites More sharing options...
Monte7071 Posted March 21, 2012 Share Posted March 21, 2012 Glad you got the problem fixed. Quote Link to comment Share on other sites More sharing options...
