Rock Posted January 29, 2014 Share Posted January 29, 2014 As long as I have the back seat pulled apart I might as well replace the package tray. It is kind of looking like crap. I was thinking of using 3/8 mdf with some kind of fabric glued to it. I haven't taken it apart yet but is 3/8 to thick? Quote Link to comment Share on other sites More sharing options...
stangeba Posted January 29, 2014 Share Posted January 29, 2014 Water leaks from the rear backlite cause the damage. Fix the leaks first if you can. 3/8 I believe is too thick. OEM was cardboard with some insulation glued to it. I still have my original someplace. When I was restoring my 71 back in like 1986, my neighbor had two made at the GM Tech Center in Warren, Michigan, one for his Chevelle and one for my Monte. They were some sort of cardboard, very thin, covered in the "then popular" Velcro looking black mat material. It has held up perfectly. He even had speaker holes built in, that you can't see, so I didn't need the metal 6" x 9" grills. Man that was a long time ago! Good luck but be careful of that snowball effect! Bruce Quote Link to comment Share on other sites More sharing options...
footballubet Posted January 29, 2014 Share Posted January 29, 2014 That would be too thick. If you didn't want to go the stock part route you may find a sheet of paneling the right thickness and cover that. Quote Link to comment Share on other sites More sharing options...
Murphy Posted January 29, 2014 Share Posted January 29, 2014 I agree with Scott, as I recall when I replaced mine with the OPG part, the replacement was only about an 1/8" thick, maybe 3/16". What I removed was very similar but was basically powder so I couldn't get a true measurement, just sucked it up with the shop vac............ Quote Link to comment Share on other sites More sharing options...
Rock Posted January 29, 2014 Author Share Posted January 29, 2014 Wow it's that thin? Pretty sure the leaks are fixed but the package tray is warped and someone put some fabric over the warped piece. Looks kinda bad. Guess I Will take it apart and see what I have to replace it with. I seen what they have at OPG and wasn't too thrilled with the reviews of the product so I will try and engineer something myself. Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted January 29, 2014 Share Posted January 29, 2014 try some of the other suppliers on our parts page, OPGI is notorious for back orders, and many are cheaper too Quote Link to comment Share on other sites More sharing options...
cny first gen 71 Posted January 29, 2014 Share Posted January 29, 2014 I made mine out of 1/4 inch masionite and covered it with some thin carpet I found at walmart. I used the old one at a template and marked it and cut it with jig saw. It really wasnt that hard and didnt come out bad at all. Quote Link to comment Share on other sites More sharing options...
Rock Posted January 29, 2014 Author Share Posted January 29, 2014 Â Heres the package tray. You can see that the material is real wavy and believe it or not it was glued down. I like the masonite idea....hard surface that wont warp under heat. Just can't decide if I should go with Gray or black. The interior is black and I thought the gray would look nice with the black speaker grills and match the outside of the car. Quote Link to comment Share on other sites More sharing options...
Murphy Posted January 29, 2014 Share Posted January 29, 2014 Hey Rock, I've seen a lot of different methods on the package tray, I like the contrasting color option. I also liked the idea of using vinyl w/foam backing (1/8") it makes it slightly puffed up which hides any wrinkling and it's a breeze to clean vs cloth! Quote Link to comment Share on other sites More sharing options...
Rock Posted January 29, 2014 Author Share Posted January 29, 2014 Hey Rock, I've seen a lot of different methods on the package tray, I like the contrasting color option. I also liked the idea of using vinyl w/foam backing (1/8") it makes it slightly puffed up which hides any wrinkling and it's a breeze to clean vs cloth! Â Starting to think that also!! Quote Link to comment Share on other sites More sharing options...
72jrfan88 Posted January 29, 2014 Share Posted January 29, 2014 I didn't know that the package tray had fabric over it. Mine looks like a piece of heavy cardboard that is black with a vinyl seal that seals against the backseat. Mine was replaced in 1986 at a chevy dealer here in wisconsin. I have receipt and previous owner was a manager at the dealership. Did he just not put the fabric back over it? I also have one speaker cutout on passenger side rear Quote Link to comment Share on other sites More sharing options...
Canuck Posted January 29, 2014 Share Posted January 29, 2014 I didn't know that the package tray had fabric over it. Mine looks like a piece of heavy cardboard that is black with a vinyl seal that seals against the backseat. Mine was replaced in 1986 at a chevy dealer here in wisconsin. I have receipt and previous owner was a manager at the dealership. Did he just not put the fabric back over it? I also have one speaker cutout on passenger side rear  Yours is the correct factory one Eric. Quote Link to comment Share on other sites More sharing options...
Rock Posted January 29, 2014 Author Share Posted January 29, 2014 I didn't know that the package tray had fabric over it. Mine looks like a piece of heavy cardboard that is black with a vinyl seal that seals against the backseat. Mine was replaced in 1986 at a chevy dealer here in wisconsin. I have receipt and previous owner was a manager at the dealership. Did he just not put the fabric back over it? I also have one speaker cutout on passenger side rear  Mine has the original cardboard package tray except someone spray glued a black felt piece over it....looks like crap which is why I want to replace it. Pretty sure it will crumble when I try and take it out. Quote Link to comment Share on other sites More sharing options...
72jrfan88 Posted January 29, 2014 Share Posted January 29, 2014 Ok thanks. My 97 monte has the felt glued on but all modern cars seem to. Im sure the cardboard will be brittle and defaced since it was glued. Maybe a good factory replacement with dual speaker cutout s will work nicely in your car in black Quote Link to comment Share on other sites More sharing options...
Andreas Posted January 29, 2014 Share Posted January 29, 2014 If you are not too concerned about staying original, National Parts Depot has a hard plastic package tray with 6x9 speaker pods and a 3rd brake light (optional) integrated.... Â Quote Link to comment Share on other sites More sharing options...
Leghome Posted January 30, 2014 Share Posted January 30, 2014 My tray looks like a coarse screen over cardboard. It looks original but I do not know for sure. Quote Link to comment Share on other sites More sharing options...
Murphy Posted January 30, 2014 Share Posted January 30, 2014 My tray looks like a coarse screen over cardboard. It looks original but I do not know for sure. Sounds like the OPG part, Larry. This what I install a few years back when it was only available in Black and $20 cheaper! http://www.opgi.com/monte-carlo/1970/interior-accessories/package-tray/RSS62/ Quote Link to comment Share on other sites More sharing options...
monte70car Posted January 31, 2014 Share Posted January 31, 2014 Here is a finish picture of the package tray Andreas posted Quote Link to comment Share on other sites More sharing options...
MCfan Posted January 31, 2014 Share Posted January 31, 2014 Here is a finish picture of the package tray Andreas posted  Halleluiah! I have wondered for years what your avatar picture actually was, Robert ... now it finally makes sense!! Quote Link to comment Share on other sites More sharing options...
monte70car Posted February 1, 2014 Share Posted February 1, 2014 Dennis if you like that you would love one of the pictures I did when the fan shroud was removed. Should see the one I use on face book Quote Link to comment Share on other sites More sharing options...
Rock Posted February 1, 2014 Author Share Posted February 1, 2014 Here is a finish picture of the package tray Andreas posted How do you like it? Do you have a pic from the front? Quote Link to comment Share on other sites More sharing options...
monte70car Posted February 1, 2014 Share Posted February 1, 2014 Glen here is probably the only picture of the package tray I have from the front There is a gap from where the package tray stops and the top of the back seat as I didn't have the front trim piece for the package tray. It's a nice unit kinda gives the back seat that it has head rest. The 6x9 mounts gets the sound up and over the rear seat. Quote Link to comment Share on other sites More sharing options...
Rock Posted February 21, 2014 Author Share Posted February 21, 2014 Finally finished the package tray....let me know what ya think. I tried a dark gray for contrast but didn't like the results.Decided to stick with black. I bought some black automotive carpet off EBAY and was extremely happy with what they sent me.....very nice short nap and looks really good in my opinion. Â Â Â Â The before. URL=http://s775.photobucket.com/user/glnewman3118k/media/Mobile%20Uploads/20140125_210644_zpsfcec00a5.jpg.html][/url] Quote Link to comment Share on other sites More sharing options...
70 Iron Posted February 21, 2014 Share Posted February 21, 2014 Looks Great ! Nice and neat ,good job  Terry Quote Link to comment Share on other sites More sharing options...
abe72 Posted February 21, 2014 Share Posted February 21, 2014 Rock, that turned out real nice. I just redid mine a few weeks ago myself. I used brown felt as it matched the carpet(tray looked browish too). Quote Link to comment Share on other sites More sharing options...
