Guess the HP Game!!
dbreese
Ok guys and gals. I have scheduled some engine dyno time for next Monday afternoon. I'll post up the build. Closest one to the peak fwhp number wins and will receive a prize (TBD). yay
414 ci 10.5:1 cr pump gas
World Motown 400 block 4.125
Callies Compstar Crank 3.875" stroke
Eagle H-beam Rods 5.85" L-19 bolts
JE Pistons inverted dome -16cc
Rollmaster timing set
Cometic Head Gasket .040
Cammotion low lash billet soild roller
in lift .688 in dur 254 @ .050
ex lift .631 ex dur 262 @ .050
110 LSA
Profiler 210 cc heads 64 cc combustion chamber. Mild runner, port and bowl blend work
REV stainless steel 2.08 in valves and 1.60 ex valves
PAC Dual valve springs
PAC Titanium retainers
Trend 7/16" push rods
Morel Ultra Pro lifters
Jesel sportsman shaft rockers 1.6 in 1.5 exhaust.
Moroso oil pan and pickup
melling m55 hv oil pump
vic jr intake/ port matched with worked over runners, plenum and runner dividers.
prosystems 950 carb
msd e-curve distributor/ blaster 2 coil 8.5 wires
That is pretty much it. I will video the pulls and post the dyno sheets when we're done. Good luck and let the guessing begin! I'm not very puter savvy so if someone could come up with a way to keep the names and hp choices in some kind of order that would be great.
David
  • Replies 62
  • Created
  • Last Reply
Top Posters In This Topic
Originally Posted By: Heckeng
Ok, I'll be the crazy guy here. . .
I say 600hp, and 550lbft shocked
This is going to be a screamer!
yeah, maybe with a blower...... not to be a pessimist.
I think this is absolutely reasonable. The cam is big, so HP is going to be high, higher than the torque values. My friend made 430hp with a 383, AFR 195 heads, and a 236/242 HYDRAULIC roller cam. David is using a Solid roller even bigger, with 30 more cubic inches and better flowing heads and a SP intake. I think you guys are underestimating this beast. Hopefully I'm not getting David's hopes too high, but I think this will be impressive.
devil Go Dave, Go Dave, Go Dave!!! devil
There is a HUGE difference between 430 HP and 600 HP. I hope it puts out a bunch of power for him, but 600 horse in a 414" engine ain't as easy as people think. Most guys in that range are using 500+ inch big blocks.
Not to be a negative Nancy, but let's be Robbie realistic. I'm going off my experience with my engine. He has 5 cubic inches more than me. I would not say his heads are any better than mine, we have the same size carb from the same place. Around the same compression. Now granted, I haven't had mine on the engine dyno, only a chassis, but lets say a 20% dt loss, what would put mine at 482 the last time I dyno'd. I did change carb, intake rocker ratio and intake since then. It picked up a couple MPH, so lets say it's at 500 now.
He does have a bigger cam,(mine is a solid too) but 100 HP with just a cam change is a bunch.... I guess we'll see. And to get to 600, your gonna have to wind the snot out of that mofo.
