AL M Posted September 18, 2010 Share Posted September 18, 2010 Hey guys, took her out for a cruise this evening and went to hammer down the parkway. Nothing crazy, just a blast on and off, 1 short run to my exit. As I pulled off I felt the idle drop a bit as I rolled to a stop sign. I also felt a lil spudder in the pedal. Then I heard this clanking...like a rod knock. It had great oil pressure and I was only 1/10th of a mile away from home so I just limped it home...Called Steve and he told me to take the valve covers off to look and see if anything was loose or off...it checked out good. Then I took off the flywheel cover and looked up at the converter bolts and flywheel..I noticed a slight graze on the flywheel and had my dad fire her up as I looked underneath...I thought I saw a slight wobble to it....Can a cracked flywheel sound like a rod knock? It sounds like metal balls rattling in a coffee can. Steves stopping by tomorrow to hear it. In the mean time tell me what you make of it...im done w/it for tonite...Al Quote Link to comment Share on other sites More sharing options...
Heckeng Posted September 18, 2010 Share Posted September 18, 2010 It can definitely make metal on metal noises. I've had converter bolts loosen up and cause noises too, kind of a rattely rocks in a can sort of sound. Quote Link to comment Share on other sites More sharing options...
dbreese Posted September 18, 2010 Share Posted September 18, 2010 Hi Al, Â Yep a cracked flexplate or loose converter bolts can make that awful noise. I had a converter bolt loosen on me and it sound bad like a rod knock. Â David Quote Link to comment Share on other sites More sharing options...
Chevyss Posted September 18, 2010 Share Posted September 18, 2010 Cracked flexplate can make a lot of noise. I know I've had my fair share of them over the past three years. Good luck Quote Link to comment Share on other sites More sharing options...
Riznitch Posted September 18, 2010 Share Posted September 18, 2010 Hold my breath for you! hope its something simple. Quote Link to comment Share on other sites More sharing options...
Ian Posted September 18, 2010 Share Posted September 18, 2010 Hold my breath for you! hope its something simple. Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted September 18, 2010 Share Posted September 18, 2010 I agree with everyone else Quote Link to comment Share on other sites More sharing options...
jim's 70 Posted September 18, 2010 Share Posted September 18, 2010 Throw in another flywheel vote. We get them at work all the time. Sounds like a rod is ready to take a trip out the botoom of the oil pan... Quote Link to comment Share on other sites More sharing options...
7tonemonte Posted September 18, 2010 Share Posted September 18, 2010 Hopefully its just a loose bolt Al! Keep us posted. Quote Link to comment Share on other sites More sharing options...
black07ss Posted September 18, 2010 Share Posted September 18, 2010 I agree Loose bolts or a cracked flywheel will sound like a rod knock but it will be a little more tinny sounding. You can check the flywheel by taking out the converter bolts and push the converter away from the flywheel.With the converter not touching the flywheel take a hammer and tap the flywheel. If you get a nice chrisp ping the flywheel is good. If you get a thud sound it will have a crack Quote Link to comment Share on other sites More sharing options...
502ci Posted September 18, 2010 Share Posted September 18, 2010 Hold my breath for you! hope its something simple. Quote Link to comment Share on other sites More sharing options...
CrazyDavey Posted September 18, 2010 Share Posted September 18, 2010 Â Â may the force be with you Al!!! Quote Link to comment Share on other sites More sharing options...
Mike 57 Posted September 18, 2010 Share Posted September 18, 2010 I have heard a flex plate cracked around the bolts sound just like a rod knock. I hope that is it. Quote Link to comment Share on other sites More sharing options...
AL M Posted September 19, 2010 Author Share Posted September 19, 2010 If it is a cracked flywheel will these previous periodic start ups hurt? I let it run to let more experienced ears here it today. Steve came over. We pulled the valve covers off again, all is good, inspected the flywheel and starter, again, all is good. even did a cyclinder check pulling each boot off the plugs, noise didnt go away. maybe the flywheel bolt is cracked directly under the bolt head Mike. Hope its just the flywheel. I always tend to think of the worse case senario........So, since I'm thinking.....do I go Little "M" and build a big ci small block or go BB...lololol...if I do it again, the main goal is to beat 12.0 and regain my thrown from Steve...lololololol!!!!! I may be coming to get ya Steve .....ONE MO TIME!!!!! Quote Link to comment Share on other sites More sharing options...
Phil Posted September 19, 2010 Share Posted September 19, 2010 Al, first you have the man come out and give you his opinion and then you plot to overthrow his Kingship....I like it! Â Good luck, hope it's nothing. Quote Link to comment Share on other sites More sharing options...
Steve Wagner Posted September 19, 2010 Share Posted September 19, 2010 He's gonna be asking Steve his opinion anyway on what to do to beat him...Steve could just sandbag it and mislead him. I don't think Steve would do it though. He will give him the proper guidance and then plan his counter attack. Good Luck Al, hope it's not a major problem because there is always nitrous to meet the goal. Quote Link to comment Share on other sites More sharing options...
black07ss Posted September 19, 2010 Share Posted September 19, 2010 A crack will be hard to see. They always crack between or around the bolts at the crank. Did you take the converter loose and tap it? Quote Link to comment Share on other sites More sharing options...
footballubet Posted September 19, 2010 Share Posted September 19, 2010 I agree with the masses here. Take the converter bolts out and tap it. Â Â Quote Link to comment Share on other sites More sharing options...
AL M Posted September 19, 2010 Author Share Posted September 19, 2010 I love stirring the pot...I'll get at it during the week and let you guys know...and for the record..Steve is a god saint! He saves me and helps me out all the time. This noise is new to him as well so i welcome him chiming in at any time..... Quote Link to comment Share on other sites More sharing options...
Phil Posted September 19, 2010 Share Posted September 19, 2010 We know you're just pulling Steves chain Al. Quote Link to comment Share on other sites More sharing options...
71monteme Posted September 20, 2010 Share Posted September 20, 2010 Al. long shot here, where is the noise coming from? i had valve springs break and sounds like knocks, what valve springs are you running? single, dual? i broke 4 inner springs and did not know it until 1 started to knock, then i took them all off and that's when i found the other broken springs. like i said maybe a long shot. good luck  thanh Quote Link to comment Share on other sites More sharing options...
AL M Posted September 22, 2010 Author Share Posted September 22, 2010 What I didnt mention in my last 2 posts was this....2 weeks ago I pulled over to check to see if my carb was leaking and when I took the aircleaner off I fumbled the lid and the wingnut and washer went flying...needless to say I found the wingnut but the washer dissappeared. I looked everywhere but I didnt find it. Of course I was smart enough to look down in the carb but didnt see anything. I drove the car 2 other times and it was fine, then last friday I got on it and thats when I heard the noise. I guess I didnt look hard enough. It got sucked into cylinder #7. I pulled the plug and the tip was flat like someone hit it w/ a hammer. I feel like an [censored]. The washer sat below the wingnut and was the size of a 1/4. I'm sure the cylinder wall looks like someone took a chisel to it. Who knows what kind of damage is down there....the motors coming out and off to my builder. lets see what he finds and I'll take it from there. Let the ribbing begin...lets bring it on and get it over and done with....dont worry i'm laughing at myself already now that the tears are gone..lol!! Wish me luck. Al Quote Link to comment Share on other sites More sharing options...
Mike 57 Posted September 22, 2010 Share Posted September 22, 2010 Good luck with it Al. Aluminum heads can be fixed and a cylinder can be sleeved. Sounds like you are not loosing water so it is nothing that can't be repaired. Crap happens lesson learned. I don't run an air cleaner at the strip I always remove the stud. I don't think it could get in a cylinder but it could hold the throttle open. Quote Link to comment Share on other sites More sharing options...
Phil Posted September 22, 2010 Share Posted September 22, 2010 Dang Al, well that can happen to anybody, just hope I'm not next. No more problems with the water pump then? Quote Link to comment Share on other sites More sharing options...
jim's 70 Posted September 22, 2010 Share Posted September 22, 2010 Found it !!!    Anyone else think he did this on purpose just so he could rebuild to go faster?? lol  Quote Link to comment Share on other sites More sharing options...
