MCfan Posted September 7, 2022 Share Posted September 7, 2022 AED 750 (Holley with custom valve bodies) 1 Quote Link to comment Share on other sites More sharing options...
Montemedic Posted September 7, 2022 Share Posted September 7, 2022 Quadrajet - Stock, Holly - Performance. 1 Quote Link to comment Share on other sites More sharing options...
Scott S. Posted September 7, 2022 Share Posted September 7, 2022 14 hours ago, Blake350 said: that may sum it up pretty well... Sounds about right.... With all the matched up components from the different manufacturer's, it basically a question of what you want to get out of your engine. 1 Quote Link to comment Share on other sites More sharing options...
Blake350 Posted September 12, 2022 Share Posted September 12, 2022 I have a mild sunday cruiser... I also read that once you set up an Edelbrock, they are good to go"(set it and forget it)" but for freguent changes(ie better tuneability) the performance guys prefer Holley... I put a 600 cfm eddy1406 on a very mild 350... due to its "tuned for economy" I changed primary metering jets and rods to richen it up a bit and she has been perfect for my needs for over 15 years... 4 Quote Link to comment Share on other sites More sharing options...
Leghome Posted September 12, 2022 Share Posted September 12, 2022 6 hours ago, Blake350 said: I put a 600 cfm eddy1406 on a very mild 350 I just removed a 1406 from my mild 350 and went with a Holley Sniper EFI. the 1406 was straight out of the box 10 years ago with only minor adjustments to make the engine purrrr purfectly. Removed a Holley because it would not run very well with it. 2 Quote Link to comment Share on other sites More sharing options...
Scott S. Posted September 13, 2022 Share Posted September 13, 2022 Montelishi came with a 1405, plus the matching cam and intake. She was jetted for lower elevations, so when she got to the mountains, I had to lean ot the jetting quite a bit....... But working on Edelbrock is pretty simple. 1 Quote Link to comment Share on other sites More sharing options...
420ponies Posted September 13, 2022 Share Posted September 13, 2022 Holley 750 vacuum sec. First 10 yrs,now Holley Brawler 750.runs much better just out of the box.had to reduce the rear jets though,82's down to 76's. Quote Link to comment Share on other sites More sharing options...
Tom Carter Posted September 13, 2022 Share Posted September 13, 2022 I have been and Edelbrock fan since the 90's I put the new AV2 on the engine last year. its a 650 instead of the 600. there is total throttle response. It drives like a throttle body fuel injected engine in my opinion. Edelbrock is much easier to jet up. You don't have to disassemble the carb to play with the jets. In fact, you don't have to remove the carb at all. I respect Holly but you seem to have more adjustments to maintain. I set up my AV2 and its good until I fool around with it because I want to. Not because I have to. 3 Quote Link to comment Share on other sites More sharing options...
BobW Posted October 24, 2022 Share Posted October 24, 2022 I was just gifted this spreadbore manifold. I currently have the stock 2 barrel on my '72. I had a 1405 Edelbrock on my '37 Pontiac with chevy 350 for years. Always ran great. Will this manifold work well with an adapter, or should I search for another manifold to run an edelbrock. 3 Quote Link to comment Share on other sites More sharing options...
Michael Boyte Posted October 24, 2022 Share Posted October 24, 2022 2 hours ago, BobW said: I was just gifted this spreadbore manifold. I currently have the stock 2 barrel on my '72. I had a 1405 Edelbrock on my '37 Pontiac with chevy 350 for years. Always ran great. Will this manifold work well with an adapter, or should I search for another manifold to run an edelbrock. Very nice gift to receive there !! There's nothing quite like the moaning of a spreadbore !!!! If you choose to use the factory air cleaner assembly , Don't forget to flip the breather cover !! 4 1 Quote Link to comment Share on other sites More sharing options...
MonteLady Posted October 25, 2022 Share Posted October 25, 2022 Quadrajet and Edelbrock.I have tried Holley carbs,too finicky and nothing but troubles with them 1 1 Quote Link to comment Share on other sites More sharing options...
MC1of80 Posted October 25, 2022 Share Posted October 25, 2022 44 minutes ago, MonteLady said: Quadrajet and Edelbrock.I have tried Holley carbs,too finicky and nothing but troubles with them What's finicky about them? Lol 1 Quote Link to comment Share on other sites More sharing options...
MonteLady Posted October 26, 2022 Share Posted October 26, 2022 23 hours ago, MC1of80 said: What's finicky about them? Lol Tried running them and would not perform Quote Link to comment Share on other sites More sharing options...
MC1of80 Posted October 26, 2022 Share Posted October 26, 2022 Okee dokey. 2 Quote Link to comment Share on other sites More sharing options...
BobW Posted October 30, 2022 Share Posted October 30, 2022 On 10/24/2022 at 6:34 AM, BobW said: I was just gifted this spreadbore manifold. I currently have the stock 2 barrel on my '72. I had a 1405 Edelbrock on my '37 Pontiac with chevy 350 for years. Always ran great. Will this manifold work well with an adapter, or should I search for another manifold to run an edelbrock. Just picked up a Holley 80555 spreadbore to mount on the manifold. Quote Link to comment Share on other sites More sharing options...
Scott S. Posted October 31, 2022 Share Posted October 31, 2022 Personally, I'd look for another carb... Depending on if you want to go stock. I like the Edelbrock carbs, but they don't mix with factory pieces like Holley does. And an adapter can throw the linkage geometry out of wack. 4 Quote Link to comment Share on other sites More sharing options...
Whons Posted November 6, 2022 Share Posted November 6, 2022 I like the Edelbrock carbs. they perform well for me. They are easy to work on. You can change the jets without taking the carb. apart. But you have to have a pressure regulator as they require a max of 6 psi. Quote Link to comment Share on other sites More sharing options...
Scott S. Posted November 6, 2022 Share Posted November 6, 2022 6 hours ago, Whons said: I like the Edelbrock carbs. they perform well for me. They are easy to work on. You can change the jets without taking the carb. apart. But you have to have a pressure regulator as they require a max of 6 psi. A high volume fuel pump works too.... Something from a Corvette or performance Camaro usually runs around 8 psi. 1 Quote Link to comment Share on other sites More sharing options...
Scott S. Posted November 6, 2022 Share Posted November 6, 2022 Just now, Scott S. said: A high volume fuel pump works too.... Something from a Corvette or performance Camaro usually runs around 8 psi. Sorry, I meant they use a larger fuel line.. 5/8" as opposed to the 1/2", which lowers the pressure to about 5 psi. Sunday morning after time change fog.... lol Quote Link to comment Share on other sites More sharing options...
Dtret Posted November 6, 2022 Share Posted November 6, 2022 30 minutes ago, Scott S. said: Sorry, I meant they use a larger fuel line.. 5/8" as opposed to the 1/2", which lowers the pressure to about 5 psi. Sunday morning after time change fog.... lol That’s a big fuel line ? That’s heater hose size. 3/8 vs 5/16. 2 Quote Link to comment Share on other sites More sharing options...
Scott S. Posted November 7, 2022 Share Posted November 7, 2022 Again.... Sunday morning..... I'm still sizing lines by the size of wrench used to undo the fittings. Quote Link to comment Share on other sites More sharing options...
Dtret Posted November 7, 2022 Share Posted November 7, 2022 2 hours ago, Scott S. said: Again.... Sunday morning..... I'm still sizing lines by the size of wrench used to undo the fittings. Ok. I’ll buy that. 👍 Quote Link to comment Share on other sites More sharing options...
Michael Boyte Posted November 7, 2022 Share Posted November 7, 2022 Ditto !!! Quote Link to comment Share on other sites More sharing options...
Scott S. Posted November 8, 2022 Share Posted November 8, 2022 Thanks.... lol. Quote Link to comment Share on other sites More sharing options...
BobW Posted November 10, 2022 Share Posted November 10, 2022 On 11/7/2022 at 1:56 PM, Scott S. said: Again.... Sunday morning..... I'm still sizing lines by the size of wrench used to undo the fittings. You must have fun at the parts counter! 😉 1 Quote Link to comment Share on other sites More sharing options...
