Panel gaps on new quarter panel
72RustBucket
Hey everyone! It's been awhile, working a lot of overtime so not much headway on the monte except stacking new parts lol. I'm working on installing new drivers quarter panel and outer wheel well. I have the well tacked in, apparently in the exact spot it should be according to my lines and measurements. Been fiddling with the new quarter and I think I've got it as good as it will get. All the gaps along the trunk, tail light extensions, rear window, well lip, rocker panel are good. They are all straight, even, and match the other side which is still factory.
The gap between the quarter and door however is larger than it should be. It's not a ton but enough to notice. I'll get pics up when I'm at the shop tomorrow. The doors were removed to replace hinge pins but the hinges were never moved so there shouldn't be an issue with the doors
Any advice? There really doesn't seem like there is any more that I can push the panel forward without possibly damaging/warping it, and it doesn't appear like anything is catching. I'm thinking I may need to weld a bead on the new quarter to make the gap look better. I know this is fairly common but I wasn't sure if anyone else had a similar issue with AMD full quarters.
i am not a body man either , but was told a long time ago that the quarter and door gap is the starting point when doing any panel replacement,door, fender ,hood etc body work ,good luck,roger
What's the gap/offset like at the front of the rocker panel? Might be able to move the door and still make the front work. If not I recommend adding to the door much easier than adding to the door jam.
rotin
I need more clamps, but that's near the best I can get it by myself at the moment. I also don't have the door striker in its exact spot, so not sure how much that affects things. Passenger side for reference, as it is still factory.
I'd put jack stands under the front and rear wheel locations instead of where you have them. Even though it's a full frame car, it'll still flex/sag and cause possible panel alignment problems. I see it on the lift all the time with car/trucks, sometimes to the point the doors won't open properly. Without door strikers, front fenders/inner wheel house tightened down completely, or panels welded in, it compounds problems.
Whenever I hang sheetmetal, I'll make sure to put the stands under the front lower control arms near the ball joints, and at the rear axle tubes. If there's no front suspension at the time, I'll still support it where the wheel centerlines would be located.
Not to be a dick, but cinder blocks aren't typically considered safe to lift vehicles. That being said, some bargain offshore jack stands aren't safe either, as I seem to remember there was a recall or warning about some of them not too long ago. Just hate to see someone get hurt if they crumbled and crushed you or some body parts (human parts that is, metal can be fixed).
I am NOT a body man but if the door and fender are not set how are you checking for panel gaps?  Also agree with Joe on the lifting positions but with the dirt floor I wouldn’t use jack stands either ( they sink and through frame positions off. I would opt for 2 ft long 6x6 or 8x8 wood cribbing and then shim it to a level position. If the frame isn’t straight nothing will be.
I'd just put steel plates or something under the jack stands.
Well the fenders should be ignored for the moment. They are literally just hanging there, mostly unsecured so they will be out of my way.
Will do. I was getting mixed results on where to support the car, using suspension makes sense because thats how you will be seeing the car i guess. I have the wheels off for some cleaning/ polishing and possibly new tires, but work etc has gotten away from me and i havent gotten around to finishing them up. The car was leveled when put on the blocks.
Not being a dick at all! If it makes you feel any better, i don't really get under it at all in its current state. Also, the blocks are actually BECAUSE of that recall! I had a set from harbor and stopped using them due to the recall, and im not sure how much i trust the old set we have around, so blocks seemed like a save alternative for the time being.
Basically you want the frame to be like it was sitting on the tires, so it's stressed like it would be on the ground. I can see how much a frame sags when raising the lift, especially with an engine in there & no fenders to tie it together. You'd be surprised how much those frames flex. If those quarters are off right from the start because of that, you're basically screwed because everything forward of that is based on those quarters being correct.
I keep the wheels/tires on while fitting body panels and I make sure to align the fenders and install the hood and trunk lid before I finalize anything.  It looks pretty good though for just being mocked up. Not sure if you replaced body mount bushings yet but I'd make sure to replace those now. If you are looking for dime gaps adding material to the door edge would be the way to go.
Thank you! That is the main reason for the post. I don't want to put any welds on until i know it is exactly where i want it. I dont even want to use any sheet metal screws until i know i can basically get it where  it is supposed to be with clamps.
The body mounts are all new. I'll be putting the wheels and tires on soon to see if that changes anything. I have the trunk lid half installed. I'm an idiot an didnt properly install it before removing the old quarter, so it is on, but it isnt shimmed or  tightened or positioned, but it still works to show how things can/will line up. The fenders need to be reworked, so that is why they are barely secured...i i figured its the best place for them until i rework them. I haven't put the hood on because the engine will be swapped again but the end weight shouldnt change too much. Ill get some more pics up after i get it back under its own weight.
If you have a Fisher Body Manual, it has the specs for the door, fender gaps etc. I posted a link to it somewhere around here, if you don't have one, let me know.
EDIT: Check this post here, there's a link to one:
Even more stuff here:
https://www.firstgenmc.com/forums/index.php?/topic/23286-nosreplacement-washer-squirter-nozzles/#comment-218877
Wheels back on. It helped, but I think the quarter still sits maybe 1/8 - 1/4 inch higher than the door. This may be because I don't have screws or anything holding quarter down inside the door. Possibly could move door striker a hair to bring door up? I'm very close...
