LS5 Posted February 18, 2013 Share Posted February 18, 2013 I helped a Friend (member from here) get the missing part for his monte he was looking for .... Darren. Link to comment Share on other sites More sharing options...
DRDIRT11 Posted February 18, 2013 Share Posted February 18, 2013 I removed my gas tank and found my second build sheet. Link to comment Share on other sites More sharing options...
502ci Posted February 18, 2013 Share Posted February 18, 2013 Built a tire rack in my garage for my racing wheels...still needs finishing though. Link to comment Share on other sites More sharing options...
CKZ03 Posted February 18, 2013 Share Posted February 18, 2013 Got my engine harness & some of the front lighting harness wired up. Â Was stumped for half the day because American Auto Wire's kit I am using makes no provisions for a factory A/C car, no instructions or suggestions how to tie in power to blower motor relay. After looking at several wiring diagrams and decifering how the entire A/C system controls & supporting relay, switches, resistors, etc. actually function and work together as a system, I came up with my own solution to the problem. If it wasnt Sunday I could have just called their tech support and got alot more done today A little info in their instructions would have been very helpful, I guess they figure no one has A/C Link to comment Share on other sites More sharing options...
bigtankjones Posted February 18, 2013 Share Posted February 18, 2013 Got my engine harness & some of the front lighting harness wired up. Â Was stumped for half the day because American Auto Wire's kit I am using makes no provisions for a factory A/C car, no instructions or suggestions how to tie in power to blower motor relay. After looking at several wiring diagrams and decifering how the entire A/C system controls & supporting relay, switches, resistors, etc. actually function and work together as a system, I came up with my own solution to the problem. If it wasnt Sunday I could have just called their tech support and got alot more done today A little info in their instructions would have been very helpful, I guess they figure no one has A/C Hopefully they will have these minor bugs fixed when I order mine in a few months. Link to comment Share on other sites More sharing options...
monte70car Posted February 18, 2013 Share Posted February 18, 2013 Cory you should have asked me there is a 12v orange wire and ign wire that goes into the fuse box. I put both in my fuse box and then didn't use them lol Link to comment Share on other sites More sharing options...
Mike 57 Posted February 18, 2013 Share Posted February 18, 2013 Pulled the trailer out of is hole and unloaded the car into the garage. Link to comment Share on other sites More sharing options...
CKZ03 Posted February 18, 2013 Share Posted February 18, 2013 Cory you should have asked me there is a 12v orange wire and ign wire that goes into the fuse box. I put both in my fuse box and then didn't use them lol  I thought about contacting you Robert about this, as I thought you encountered a similar situation installing yours, but remembered you were deleting your AC set up, so I figured you might not have investagated this with AAW. I wound up using the orange electric cooling fan lead to supply power to my blower motor/AC relay, seemed like the most logical & easiest option. The orange wire they tell you to use is for a non AC set up & is not fused nor connected to 12v unless you jump or splice to 12v, which I'm assuming this connection is made through the original non AC connections on back of heater controls. So in my application it seemed best to use an alternative fused supply. I also used the ignition swithced ECM feed for power to electric choke. It really is nice to have so many options available on both sides of the firewall for adding almost anything imaginable.  I'm still going to call AAW, they really should put SOMETHING in their literature for guys running factory AC. Link to comment Share on other sites More sharing options...
Its Just Me Posted February 20, 2013 Share Posted February 20, 2013 Unbolted the rear-end cover to determine if I had a bad posi unit or no posi and to determine gear ratio. I found 3.31 gears and a non posi carrier . Also found really chewed up gears in the differential . Now searching for a 3 series 12-bolt posi carrier...anyone??? Scott Link to comment Share on other sites More sharing options...
CKZ03 Posted February 22, 2013 Share Posted February 22, 2013 Still doing wiring, no sense boring you with more pictures of a wiring mess. Had to get my left fender out of the vault so I can mount it & my inner fender well for wire routing purposes. Going to be hiding the wiring for the front lighting behind & inside fender best I can. In process of rewireing the entire car with AAW's Monte kit.  Here is a sneek peek of my color though, of course pictures never do any justice as far as paint & color, but close enough.         On all this stuff I keep buying, they keep spelling Monte Carlo wrong, makes me wonder if the contents of these instructions are even correct    Link to comment Share on other sites More sharing options...
Mo's70MCs Posted February 22, 2013 Share Posted February 22, 2013 I like the color..looks like a lot of flake. Any at all or is it just an illusion? Looks like a metallic red or burgundy? Link to comment Share on other sites More sharing options...
CKZ03 Posted February 22, 2013 Share Posted February 22, 2013 This is a 2012 Mopar color, paint code is "PRP", (I KNOW) but hey I like it. Its called deep cherry crystal pearlcoat. It does have some very nice metallic/pearl to it, unfortuneately it doesnt show up very well in pics, looks great outside in the sun though. The true color & metallics are not represented very well in this pic, but you get the general idea. Â Link to comment Share on other sites More sharing options...
LostnFound Posted February 22, 2013 Share Posted February 22, 2013 I love the colour! "Chevelle" is an Italian word meaning "Monte Carlo" Link to comment Share on other sites More sharing options...
mbeigh Posted February 24, 2013 Share Posted February 24, 2013 Just finished up installing:  upper and lower rear control arms  front and rear sway bars  end link bushings  pittman arm   Make a world of difference Link to comment Share on other sites More sharing options...
Sam (Bones) Posted February 24, 2013 Share Posted February 24, 2013 ready to drop it in except for a few decals  Link to comment Share on other sites More sharing options...
jim's 70 Posted February 24, 2013 Share Posted February 24, 2013 That's purty right there!! Link to comment Share on other sites More sharing options...
LostnFound Posted February 24, 2013 Share Posted February 24, 2013 Looking great Sam. A job well done indeed!. It looks like it should be in a museum. Link to comment Share on other sites More sharing options...
cudax Posted February 24, 2013 Share Posted February 24, 2013 Very Nice! Link to comment Share on other sites More sharing options...
Mo's70MCs Posted February 25, 2013 Share Posted February 25, 2013 Nice! You keeping the standard ignition? Link to comment Share on other sites More sharing options...
Sam (Bones) Posted February 25, 2013 Share Posted February 25, 2013 Nice! You keeping the standard ignition? Â yep, good ol' fashion points, TSC hooked up (not sure if it works) Â trying to decide whether to go stock mufflers or give it a little rumble Link to comment Share on other sites More sharing options...
monte70car Posted February 25, 2013 Share Posted February 25, 2013 Two welding blankets later the patch panel is in it's new home. Most of the studs are coming though the firewall just got the two up front in the patch panel to drill and figure out where the heater core lines go Link to comment Share on other sites More sharing options...
footballubet Posted February 25, 2013 Share Posted February 25, 2013 Got it pulled away from it's winter resting spot. Need room around it so I can install the remote power door locks and trunk release that are in our Group Buy. I'll be doing the install and giving it my review for everybody else. Link to comment Share on other sites More sharing options...
black07ss Posted February 25, 2013 Share Posted February 25, 2013 Got it pulled away from it's winter resting spot. Need room around it so I can install the remote power door locks and trunk release that are in our Group Buy. I'll be doing the install and giving it my review for everybody else. Â Sounds great!! I can't wait for you to do mine Link to comment Share on other sites More sharing options...
footballubet Posted February 25, 2013 Share Posted February 25, 2013 Originally Posted By: footballubet Got it pulled away from it's winter resting spot. Need room around it so I can install the remote power door locks and trunk release that are in our Group Buy. I'll be doing the install and giving it my review for everybody else.  Sounds great!! I can't wait for you to do mine  You better hurry up and get your's done before I'm so old I won't remember how to! Link to comment Share on other sites More sharing options...
NewTimer Posted February 25, 2013 Share Posted February 25, 2013 Cleaned up power window wires and connection, soldiered them all to make sure connections are not a problem! Link to comment Share on other sites More sharing options...
